Old 19-06-2009, 07:07 PM   #1
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
Default au11 manual conversion urgent help!!!
hey guys i bought myself an au11 futura its a 2000 model and auto.
my question is this
would the following bits suit to convert it to manual.
ED 5spd
ed speedo cable
ed malwood pin
ed clutch in the box
clutch cable
ed tail shaft
i know that these engine blocks are the same virtualy.
the only thing i know wont suit is the ed manual ecu.
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 07:22 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Im pretty sure the E'series shifter is located either further forward, or further back then the AU.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 19-06-2009, 07:27 PM   #3
GeoNazi
my question is this
ED 5spd
ed speedo cable
ed malwood pin
clutch cable
ed tail shaft
ED 5spd
No. Gearbox is too short the AU box is longer
ed speedo cable
WT? Speedo Cable? The Speedo is electronic and interchangable from EA to AU
ed malwood pin
Yes. AFAIK it is the same pin and the clutch pedal bits are interchangeable from EA to AU
Hmmm. It should.... Don't quote me.
clutch cable
Yes. AFAIK it is the same part no. from EA to AU
ed tail shaft
Hmm. I don't really know as I have seen pictures from EBII with AU and they stand nearly the same height but if I can recall the AU is a tad smaller or longer sorry mate can't remeber
GeoNazi is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 07:29 PM   #4
GeoNazi
This is cause the box is longer.
Old 19-06-2009, 07:54 PM   #5
bodes-sh
as above, au box is longer than e series, although i do believe someone fitted one, but they had to make a weird looking gear shifter. you wouldn't be able to get a short shifter for it. tail shaft from the ed would probably be too short to fit in an au, most people that do the conversion get their current shaft shortened and rebalanced. good luck
Old 19-06-2009, 08:01 PM   #6
NC1183
NC1183's Avatar
E-series gearbox will have the shifter closer to the centre console.
THe clutch cable will go as its the same cable from XF 5-speed on-wards, the XE 4-speeds had the clutch fork on the drivers side of the box.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 08:11 PM   #7
au11futura
au11futura's Avatar
hmm well the only thing i heard was different is that only four bolts match up from the bellhousing enstead of six.
and damn this box has a short shifter..
hmm.
thanks guys
Old 19-06-2009, 08:16 PM   #8
bodes-sh
hmm.
thanks guys
that's more to do with people dropping au motors into e series...
Old 19-06-2009, 08:22 PM   #9
au11futura
au11futura's Avatar
well i wonder if anyone would swap an au manual box and tail shaft for a whole ed with 5spd set up.
you think a wrecker would go for that.
Old 19-06-2009, 08:30 PM   #10
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Sorry to hijack thread but just wanted to ask why the AU gear box is longer.
Is it because the AU runs a T5Z and the extension housing is longer ?
Regards, Craig,
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 08:32 PM   #11
au11futura
au11futura's Avatar
thats cool wouldn,t mind knowing that myself.
good question
Old 19-06-2009, 09:03 PM   #12
bodes-sh
i'm not entirely sure, but i have a feeling the au has a longer input shaft and longer bellhousing...
or it could be what you said with a longer extension housing... if it's the input shaft i guess you could get an au one and belt that in it...
Old 19-06-2009, 09:17 PM   #13
au11futura
au11futura's Avatar
i hope i can find out for sure whats needed as i realy want to start the manual conversion asap.
Old 19-06-2009, 09:51 PM   #14
NC1183
NC1183's Avatar
Regards, Craig,
The base model, and early XR's run the standard T5, only the high-output V8's, ie 220kw's run the T5Z, as far as i recall. I can't remember the exact difference, but it has something to do with the extension housing as to why they are longer
Nathan
The SP
The old ute (sold)
Build Thread
