Old 08-07-2009, 11:22 PM   #1
csv8
csv8's Avatar
Exclamation E10 Not as Economical...
RUNNING your car on the ethanol-blend petrol E10 may not be the good deal it looks, according to Queensland's peak motoring body.
The RACQ said a minimum of four cents a litre discount was needed to compensate for the higher fuel consumption when using E10 blends.
The lower octane level of E10 blends means cars go fewer kilometres for every litre of fuel consumed.
Major petrol station chains are typically offering two to three cents a litre discount on E10, RACQ's general manager for external relations Gary Fites said.
"With E10 increasingly being headlined on service station price boards because of its slightly lower pump price, it can look good buying for cost-conscious motorists," Mr Fites said in a statement.
"With RACQ's own field testing confirming other independent research that indicates around three per cent higher fuel consumption when using E10, a minimum discount of four cents a litre would be needed at current price levels to make use of the ethanol blend more economical than regular ULP."
Mr Fites said motorists who want to get the best value fuel should make a close check on the relative pricing of regular unleaded petrol and E10.
CSGhia
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2009, 11:33 PM   #2
KPOJ
in a race car you use 35% more e85 then unleaded, but in a forced induction application the stuff is unbeatable.
KPOJ is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 12:10 AM   #3
uranium_death
uranium_death's Avatar
Yeah...something similar was posted recently.
I personally don't want to use it, because I have no idea what effect it will have long term.
I'll let others be the guinea pigs. I'll stick with 91.
Practicing - Sleeping with a guitar in your hand counts, as long as you don't drop it.
Don't snap my undies.
uranium_death is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 12:22 AM   #4
XRQTR
TBA Customs
XRQTR's Avatar
I'll let ya'z know in a couple of days or so how much better or worse it runs in a Holden V8, driving my brothers Senator at the moment, just got 11.2 l/100 running BP 91 regular but filled with Apco 95 e10 today. So by Monday night I rekn it should be ready for a refill, I'll post up the difference then.
I tried it once before in my Z, with the triple carbs it wasn't too bad, I actually noticed a little better response down low though on the Z, but consumption was up around 1-1.5 l/100 more with the ethanol blended fuel.
XRQTR is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 12:45 AM   #5
KPOJ
It is very reactive with some fuel system materials, only certain materials wont degrade. And it should make more power its 10% alcohol hence why it burns cooler.
Old 09-07-2009, 06:40 AM   #6
chevypower
chevypower's Avatar
E10 has been around long enough now, I am pretty sure they don't even need to advise you anymore if it has up to 10% of ethanol in regular?
Even when knowingly put in E10, I haven't noticed a loss in power or economy over E-Zero.
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 08:07 AM   #7
dallasv8
5.8 litres of fun
dallasv8's Avatar
i found when i was running E10 in my '95 EF that had over 280000km on it that i was changing fuel filters at least every 2 months
2003 RTV
2015 Ranger XLS mk2
dallasv8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 08:21 AM   #8
downthetrack
Ive been running my RTV (6) on it whenever I can get it, don't notice any loss of power, and working out the economy the difference is only around 1-200mls/100km difference, which is close enough to even for me given possible pump/road condition differences per tank.
downthetrack is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 09:15 AM   #9
merlin
merlin's Avatar
Of course you will get lower economy - this has been proven in numerous controlled tests. How is this new news? (not directed at OP but at RACQ)
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 09:26 AM   #10
fos408
I sometimes use it in my exploder and I think the car runs better ,no power loss but definite lower milage
fos408 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 09:27 AM   #11
ebxr8240
Performance moderator
ebxr8240's Avatar
Why give our $$ to the oil companies / sheiks ??
The higher the blend the better imo..
Keep the $$ in OUR country !!!!
Engines built in future will be better tuned to run it..
It likes plenty of timing and yes more fuel..
But economy comes back with tune..
Those that have fitted turbo's with stand alone or tunable ECU will benefit greatly... My new project 1UZ turbo Celica will be runing E85...
The reason fuel filters need changing ?? It cleans the varnish off the lines etc
That the old fuel deposited..Mixes with water, so it cleans everything out..
Daily driver GTE FG..
Old 09-07-2009, 09:32 AM   #12
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Welcome to 2007 Mr Fites
Old 09-07-2009, 10:43 AM   #13
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
That would be more because there is alot of crap in your fuel tank and ethanol works as a great cleaning agent.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2009, 07:51 PM   #14
Qwik6
Unsafe @ any Speed
Qwik6's Avatar
I use United 98ron E10. Fuel consumption is the same as any other 98 fuel.
Plus its only 3c more a litre than regular unleaded.
EBII Fairmont 4.0L NA - 206rwkw E85 cocktail === 13.48@102mph
Thread here
http://www.fordforums.com.au/showthread.php?t=11334087
By HEINRICH PERFORMANCE & TUNING
E Series Falcon Image Museum on FB
https://www.facebook.com/pages/E-Ser...29864000453208
Qwik6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 12:08 AM   #15
Mick K.
Mick K.'s Avatar
I ran my BA Fairmont 4.0 on 5 tanks of Shell E10 last year and the fuel consumption was 13.9 l/100kms vs 12.5 for the next 5 tanks of Shell normal 91RON unleaded.
So at about 400kms per fill, that is 5.6 litres extra of E10 required per tank, which is well and truly worse value for money, even though it is 2-3c per litre cheaper.
So I stay away from E10. The Focus doesn't like it either.
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 09:25 AM   #16
ZA-289
ZA-289's Avatar
I ran my old EB on E10 whenever I could, got better milage and better power. Dosn't make much of a difference with the missus's suby tho....
ZA-289 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 09:33 AM   #17
brenx
brenx's Avatar
My 02 Madza gets exactly the same economy on 91 and E10 50lt = 620k's per tank. I always got the same 550k's every tank on 91 or E10 when I used to have an EL too. I check every fill against the trip meter. Lower k's on my cars (per tank) can mean a few things. ie. Right foot heavy that week, time for a service or really bad traffic.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 01:01 PM   #18
ebxr8240
ebxr8240's Avatar
If tune is slightly rich and over advanced timing or border line on unleaded??
It will possibly run better on E10.. It should for example run better on XR6's than XT's..
Keep in mind if some bodgy fuel is added?? E10 will get the blame...
The NRL of fuels..Lol...
Old 11-07-2009, 02:27 PM   #19
schultzie
Just Images
schultzie's Avatar
i ran it for 5 tanks in my ute, it ran great for the first 3 tanks then progressively got more like a pig, i think if it had a specific tune it would of been fine but the car diddnt like it... gone to premium all the way now.. car likes it but i dont lol
Fg XR8... Finished for now... Untill something breaks again OR A power Adder breaks something in the future
schultzie is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 02:38 PM   #20
MR.BA.GT.332
Now in the quad cam zone
MR.BA.GT.332's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all his work in the project section. Awesome effort.
i was about to ask if there is a high octane E10 too... guess there is.... why do the big brands only do it for the 91ron and not the 98 vesions?
i only run 98ron in my XR8, it pings badly on 91ron and not game to run the standard E10.... but if there is a high octane version id give it a go
SOLD!"KELLY" 4/72 XA Futura Sedan, Black interior, 466ci Big Block, Tremec TKO600 close ratio, Wilwood 4pot Front Discs, Disc Brake 9 inch diff & 3.50 gears, F90 17x8 17x9 Polished Simmons
"BARNEY" 2003 BA GT #332, Phantom, Boss 290, FR20 Simmons. XYZ Brakes - 355mm Rotors - 8piston Front Calipers & 4piston Rear More Mods soon!!
MR.BA.GT.332 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 02:39 PM   #21
schultzie
Just Images
schultzie's Avatar
funnily enough our united ones are 95 and cheaper then 91 go figure.
Old 11-07-2009, 02:48 PM   #22
vztrt
vztrt's Avatar
United run a 95ron, 98 ron and 100ron.
Also I believe BP are investigating a 95ron E10 as they see that there is a benefit in it.
Daniel
Old 11-07-2009, 03:22 PM   #23
wados
wados's Avatar
my xr6t is tuned on the e10 98 ron and it runs perfect on it, and it only costs about 5 cents above normal 91 unleaded
2010 50th ann. G6ET
wados is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 04:35 PM   #24
Qwik6
Unsafe @ any Speed
Qwik6's Avatar
Only 3c more in SA. Great fuel tho.
Anyone use E85?
Government banned the selling of it here from the bowser.
Thread here
Old 11-07-2009, 04:50 PM   #25
EDManual
EDManual's Avatar
I find the economy in my new elantra to be around 20% worse. If you drive around slowly its possible a only 5% worse or so, but medium pace you have to have the car so much more floored for the same performance.
Its rubbish.
EDManual is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 04:58 PM   #26
Qwik6
Unsafe @ any Speed
Qwik6's Avatar
Its rubbish.
Maybe because your flooring it around you use more?
Thread here
Old 11-07-2009, 07:27 PM   #27
sexyxe
E10 is generally rated at 95RON
It is due to Ethanol having a lower kJ per Litre than regular normal fuel.
So for eg: Ethanol has 850kJ/L where as regular petrol has 1000kJ/L so when you take that 10% of regular fuel out, you loose that 15% of energy. The higher RON is due to its ability to take higher compression and heat loads. So you are ~5% of energy down.
Its chemistry. Thats how it works...
I have used it before in my mums AUIII Falcon and find that on the highway its fairly good, but around town it seems to chew more. Go figure
sexyxe is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 07:38 PM   #28
ivorya
Mad Scientist!
ivorya's Avatar
Not sure.. albout this
I believe the Major Controlling Servo's E10 is still rated at 91( Not sure how they've altered the formula.)
I had a lengthy discussing with a Caltex owner, why should i buy his E10 when for the same $ i can drive an extra 2km the get United E10 95Ron. He had no response.
He even rang the distributer and they confirmed their E10 was 91RON.
United for me..............
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 09:12 PM   #29
mickvxbs
bogan
mickvxbs's Avatar
I filled up about a week ago in our FG xr6 ute with E10 and my avg fuel economy went from 14.1L/100 to 14.5L/100
mickvxbs is offline   Reply With Quote Multi-Quote with this Post
Old 12-07-2009, 05:58 PM   #30
EDManual
EDManual's Avatar
Absolutely, its because you have to floor it around more than usual for the same performance.
