Old 27-10-2009, 01:01 PM   #1
FORD5
FORD5's Avatar
Default cd player security code - finally
Hi guys finally got my security code for my focus's cd player after 2 weeks i finally got it had to have the cd player slipped out which took 2 mins, so finally no more silent sunday drives
FORD5 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 07:45 PM   #2
4dlvr
4dlvr
after disconnecting the battery my cd player asked for the security code, i think ive pucked it since it no longer switches on.. any idea how to get it working again?
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 10:34 PM   #3
FORD5
FORD5's Avatar
Hi 4dlvr, Yes you get 10 attempts with putting in codes, after the ten attempts if a correct code is not entered it locks permantly which then needs to be taken to your local ford dealer to be reprogrammed, if you get 2 codes wrong you then have to wait 30 minutes to try another code, then another 2 code attempts then if another 2 in- correct codes are entered its 1 hour so forth until you use out your whole ten attempts, after this it 'perm locks' and it should say 'LOCKED' on the screen instead of 'CODE _ _ _ _' what we had to have done was ring our ford dealer, then we gave them the rego number and VIN number, they typed it into the system and all it said was '0000' thats because they all need VIN and serial number which is on the side of the CD player so then we had to get the cd player slipped out, then they got the serial number, then since there system was down, they waited for them to come available again typed our VIN and serial number in it cam up with our code, they rang and gave it to us, i typed it in, BINGO!, but your've perm-a-locked yours so go see your dealer, hope that helps Cheers j
Old 28-10-2009, 12:34 AM   #4
4dlvr
4dlvr
thanx mate
much appreciated
96 EF FAIRMONT
215rwkw @7psi
Old 28-10-2009, 09:04 AM   #5
FORD5
FORD5's Avatar
Originally Posted by 4dlvr
thanx mate
much appreciated
no worrys
