RBS
Old 12-02-2010, 10:31 AM   #1
amiers
Default Lights ficker
odd little problem has just started. i have noticed that my headlights will flicker every now and then, also when i use the blinkers the dash lights flicker.
thoughts?
2018 Mustang GT
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 10:35 AM   #2
sd1800
Perhaps a grounding problem? The ground cable running from the Block>Battery isn't really up to the task from what I've read.
Try replacing this with a fatter cable.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 12:40 PM   #3
auxr
auxr's Avatar
May also consider the alternator bushes are worn or the battery maybe on the way out.
auxr is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 01:54 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yes, alt is the prime suspect.
Old 12-02-2010, 03:16 PM   #5
GK
Walking with God
GK's Avatar
I would give the battery a good charging overnight and go from there. If that's no help, it might be time to change it.
If that was no help, then I'd say the alternator. It may also be the cable, but I'd suggest either the battery or alternator will be the culprit.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 12-02-2010, 07:20 PM   #6
JC
JC's Avatar
The headlight switch could be broken - happened to mine, and it just kept flicking between low and high beam.
Ford Performance Club ACT
Old 12-02-2010, 08:45 PM   #7
bodes-sh
i second bad grounds, i have the same problem. i know my battery and alternator are both fine, so that's all i can put it down to
Old 12-02-2010, 11:39 PM   #8
urbancowboy
Check your grounds and connections etc, then get a reading of what the alt is putting out.
urbancowboy is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2010, 12:32 AM   #9
mik
mik's Avatar
battery terminals clean?
Old 13-02-2010, 09:40 AM   #10
GS608
i get the same sort of problem but the climate control display flickers with lights on with the revs, that'd be the ground yeah?
