ASL
Old 12-03-2010, 01:44 PM   #1
DougM
Default AU tailshafts:- same for auto/manual??
Hi all.
I'm lookind at converting my AU3 XR8 from auto to manual.....Do I need to change the tailshaft???
Thanks.
Doug.
DougM is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 02:57 PM   #2
Stattic
Stattic's Avatar
From memory the auto shaft is longer... it could be the other wy around but they're def not the same
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 03:10 PM   #3
Blast2
Default au tail shaft
Why do you wan't to change power ? I think tail shaft for manual is longer.
If you do change put new bearings for front and rear universals also replace diff oil check for diff noise. If your in Melb try FTG Auto Salvage for parts and enquires.
Blast2 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 10:04 PM   #4
SLO AU XR8
Auto shaft is 100 odd mm too long. Manual shaft is shorter than the Auto shaft.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 04:38 PM   #5
bartsau
bartsau's Avatar
Spot on not too sure on the exact difference but it is about the 100mm or or so.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
