Old 23-06-2010, 10:07 PM   #1
sleeper393
sleeper393's Avatar
Question Auiii Intech Hard To Start
im having trouble starting my s/3 au after it has reached operating temp , if i shut it down , then try to start again it turns over but wont fire , if i turn ign off and try again it usally fires , but i smell unburnt fuel , its like and old car with the timing out of wack, can the timing be adjusted some how, been told to ground the the pins in the diagnostic port to set the base idle , but with no dizzy , what do you move to adjust timing advance or retard.
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2010, 10:13 PM   #2
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
when was the last time the plugs, leads, coil pack where changed??
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2010, 10:37 PM   #3
sleeper393
sleeper393's Avatar
it has new plugs , leads, injectors & fuel rail , fuel filter , and pump is 18months old, coil pack is the original.
Old 27-06-2010, 10:01 PM   #4
Auturbo6
The only thing u'll see!!
Auturbo6's Avatar
Crank angle sensor. My daily did the exact same thing 6 months ago. Was hard to start warm, then one day at the shops wouldn't start at all. Easily checked with a scan tool, check wave length for crank sensor, cam sensor, and map sensor. Good luck.
Auturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2010, 11:08 PM   #5
sleeper393
sleeper393's Avatar
Talking cheers
who do i take it to , to check with scan tool , cost much ? thanks, did your fuel eco suffer whilst you had the same prob.
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
Old 28-06-2010, 08:46 AM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
you take it to a mechanic with a scan tool. nearly all of your local servo mechanics should have one by now.
Old 28-06-2010, 09:39 AM   #7
NC1183
NC1183's Avatar
I'd be changing the coil pack. They sit under the inlet manifold and do get affected by heat. Will probably solve your fuel economy issues too.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2010, 11:18 AM   #8
sleeper393
sleeper393's Avatar
Question
coils either work or they dont ? from what i've read , but saying that, it is still the original coil pack
