Hi
I have just recently purchased a AUII wagon. As all of my previous cars have been manual, I have no idea on how often I need to have the automatic transmission serviced. I looked in the owners manual, but it doesn't help. Can someone please help me with this? I know if I just go to a mechanic, they'll probably tell me it needs to be done on a yearly basis or something. Thanks Brad |
If you drive hard, in the heat or you tow i'd get it done every year at the least, you can cook the fluid pretty easy without an external cooler
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
Resident AFF detailer
I would say once a year for peace of mind, especially once your auto has done a few kms......wow you joined in September 2006 and this is your first post?!?! Welcome to AFF!!
THE AU's dont have a transmission dipstick , therefor you cant check fluid level , there a sealed unit so to speak , all that can be done by you is change the filter in the tranny pan attached to the valve body , other than that it has to go to a auto trans specialist, definetly fit a good quality external trans cooler after your service.[B]have a look below[/B]
http://www.fordforums.com.au/showthr...c+transmission
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
#5 | |||
Flairs - Truckers Delight
It would be very foolish to not do it yearly.
64 Deluxe 4 door
![]() Join Date: Jun 2007
every 20 - 25k. cheap insurance (I tow a lot)
XM Deluxe FG XR50 BA Pursuit Ute |
I was told every 40k by my mechanic which is about what i do in a year.
Just slidin'
20-30k for me. With a trans cooler. But then again, usually something breaks before that period is up and its in the shop being fixed anyway, lol.
MD Mondeo - For the family
adrian
Ford told me every 80kms.
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
#10 | |||
Just slidin'
Mind you, none of them were anyones fault but mine. Service/flush/tans cooler/stall converter Extension housing seal Extension housing broke, Extension housing seal and bush/service/flush, output shaft and a tailshaft Stall converter
i think my car went the first 170,000ks without changing the fluid
![]() it was then changed by my mechanic, then 5000ks later it went to get a powerflush and service. i didn't notice any difference in the shifting. it's been 12 months since it was changed, probably should think about it again |
#12 | |||
All Bran = Regular Member
http://www.fordforums.com.au/showthread.php?t=11293691 |
![]() Join Date: Jan 2005
For non-extreme duty (ie around town) I'd say every 40000km (or once every 2 years is fine). If twoing heavy loads reguklarkly, yearly servicing with extend the life of the transmission. Also, keep in mind that even if serviced regularly, heat will kill a box quickly, so (if) as soon as it starts to slip or bang into gear, it's time to get to a transmission place - a few hundred $$$ upfront can save thousands if you leave it slipping or banging.
