Old 06-08-2010, 09:35 PM   #1
dishpig
Only an xr6...
dishpig's Avatar
Default Debadging AU ute
Hi all, Feel like debadging my ute tomorrow whilst doing other stuff, but I heard the ford badge on the rear has two holes behind it just wondering if there's an easy way to patch these. Or do I have to bite the bullet and respray the tailgate?.
Veiw my car here
TICKFORD>>>>>>>>>>>>>>>>>>>>>>FPV
dishpig is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 09:39 PM   #2
GTP 170
There are two holes behind the ford badge and the falcon badge as well.
I removed the falcon badge from mine without knowing, and ended up using a little silastic to fill the holes to stop water getting in, then a carefull dab with some touch-up paint and a polish and it was barely noticable, i have since had the holes filled and tailgate re-sprayed though
GTP 170 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 09:53 PM   #3
dishpig
Only an xr6...
dishpig's Avatar
well if thats the case I might as well save and get a pro to do it cause I want to get rid of the door moulds as well.
Veiw my car here
Old 06-08-2010, 10:14 PM   #4
frd906
Should try and fit the ba moulds on the doors as there more flatter then the au ones
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 10:51 PM   #5
dishpig
Only an xr6...
dishpig's Avatar
Yeah that is the alternative if the getting rid of them all together is too expensive. Saw it done to a black ute at a ford show and looked fantastic, I've hated my door moulds since.
Veiw my car here
