Old 11-10-2011, 09:22 PM   #1
horseman98
Default AU II I6 vibrating and exhaust popping at idle
my car has being vibrated with the exhaust popping at idle. There is no power loss during driving. No rough idle.
The interesting thing is that all the problems have gone when I push the accelerator slightly or turn on the air conditioner. It gets better even when I open the headlight.
I have done the following jobs and nothing is changed
1. changing all 6 spark plugs
2. changing the air filter
3. cleaning the throttle body
Any advice would be welcome. Thanks
horseman98 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2011, 09:35 PM   #2
Day-mow
rexnet
Day-mow's Avatar
Default Re: AU II I6 vibrating and exhaust popping at idle
how many km on the car?
exhaust popping i would think maybe a leak or a hole in it? mine pops on decelleration. but thats normal.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 11-10-2011, 09:40 PM   #3
horseman98
Thanks mate
226,000 Km now
I will check with the exhaust this weekend.
Old 11-10-2011, 09:50 PM   #4
Day-mow
rexnet
Day-mow's Avatar
whats fuel economy like? i know blocked cats can cause issue's if you have a standard cat in its probably getting there.
Old 11-10-2011, 09:56 PM   #5
horseman98
Fuel consumption is normal. No obviously increase.
Old 11-10-2011, 10:46 PM   #6
Day-mow
rexnet
Day-mow's Avatar
probably not the cat then. hmm sounds strange. i guess just check all intake pipe joins and make sure their not leaking. and check out the exhaust side of things as well. look for holes or leaks.
Old 12-10-2011, 12:29 AM   #7
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Sounds a bit lean.....
Grab a can of degreaser and, one at a time, spray every joint in the intake setup. Any increase in revs will indicate an air leak.
What colour/smell is your exhaust?
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2011, 07:40 AM   #8
horseman98
Thanks.
I will do this job this afternoon if I have time.
Smell and colour look like normal except popping at idle.
Old 12-10-2011, 03:45 PM   #9
horseman98
That is it.
I sprayed throttle body cleaner onto the intake gasket.
The car vibrated hardly when I sprayed the first and second parts of the gasket. Then The car kept running like normal. A little while the problems came back
I will change the gasket this weekend. But I noticed that the bolts on the bottom of the gasket were very difficult to reach. Any special tools should I take to undo and tight these bolts. Thanks
Old 12-10-2011, 08:42 PM   #10
Beer Baron
Ratchet spanners.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2011, 10:25 PM   #11
Day-mow
rexnet
Day-mow's Avatar
^ +1 for that. they're pretty handy on such jobs
Old 15-10-2011, 08:42 PM   #12
horseman98
Replacing the gasket has been done this morning. I feel good though it was a pain job. She runs pretty good now.
Thanks for your help.
Old 16-10-2011, 01:00 AM   #13
mongrelEF
Bugger!
mongrelEF's Avatar
Glad to help!
