Old 07-04-2012, 06:44 PM   #1
zlcrazy
zlcrazy's Avatar
Question Annoying Towball Knock
Hi all,
When towing light loads/empty trailer there is quite alot of knocking from the trailer coupling on the towball over rough roads etc.
I towed a trailer load of wood last weekend and it was nice and quiet with the weight on it.
Now i have heard or read somewhere awhile back about the screw/nut on top of the coupling is for this reason but i dont want to touch anything to im sure.
Can anyone shed some light on this for me please.
Thanks
zlcrazy
2005 BAII Falcon XR6T - Velocity Blue
Factory Options; Sunroof, Premium Sound, Plexus Blue Cloth Trim.
Genuine Accessories; XR Scuff Plates, XR Blue Carpet Mats, Boot Liner, Cargo Net, Aux Audio Input (Boosted Type), Front & Rear Mudflaps, Headlamp Protectors, Bluetooth and Mobile Phone Holder.
[B]2000 AU2 Fairmont Wagon - Congo Green
Factory Smart Bullbar, Hayman Reese Heavy Duty 2300kg Towpack and Front and Rear Mudflaps.
zlcrazy is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 06:57 PM   #2
last fairlane
last fairlane's Avatar
Cool Re: Annoying Towball Knock
I had the same trouble with my Hayman Reece tow bar
mine had the 50mm square tongue that slid in
and was secured with a pin about 20mm in diameter
I fixed mine by using a bolt with a self locking nut
and that stopped all the no load noise
hope this helps
John
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 07:00 PM   #3
deesun
deesun's Avatar
Default Re: Annoying Towball Knock
Thats pretty right, loosen nut, tighten screw till you cant get trailer off then back it off till you can. Empty trailers will always make a racket whilst empty. Problems arise when you need to detach the trailer on a slope or where car is. Its even worse with a Haymen Reese tongue that fits in as there is more slack. I have one and it annoys me no end. Much rather a fixed tongue set up.
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 07:08 PM   #4
XR Martin
XR Martin's Avatar
Most good quality ones have an anti rattle bolt...
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 07:11 PM   #5
deesun
deesun's Avatar
hope this helps
John
Thanks for that I will try it. Any Idea where I can get a bolt etc from XR6Martin? Mine is a HR which is supposed to be a goodun why on earth wouldnt it come with a bolt?
Old 07-04-2012, 07:20 PM   #6
Kevaclone
Kevaclone's Avatar
the bolt may be underneath the hitch receiver, it is on my cruiser which has a Kaymar bar. have a look under. My old BA sedan had the bolt on one of the corners so it stopped sideways and vertical movement of the hitch
03 BA XLS 6cyl Ute-Mercury Silver
04 Subaru Liberty GT Premium
99 Toyota 105 series Cruiser TD
99 5.8M Profish plate alloy carport decoration
Kevaclone is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 07:29 PM   #7
XR Martin
XR Martin's Avatar
You should also undo the bolt when towing loads, as the extra load on it can strip the threads
Old 07-04-2012, 07:31 PM   #8
zlcrazy
zlcrazy's Avatar
Hi all,
Sorry about the confusion but no my BF Falcon SR has the standard 1600kg fixed tongue towbar.
What i am actually talking about is the nut/screw on the trailer coupling itself and if this is adjustable, nothing to do with the car.
Hopefully this is abit clearer sorry.
Thanks again
zlcrazy
Old 07-04-2012, 07:55 PM   #9
deesun
deesun's Avatar
Originally Posted by zlcrazy
Hi all,
Thanks again
zlcrazy
Post 3 Thats pretty right, loosen nut, tighten screw till you cant get trailer off then back it off till you can and tighten nut again. Empty trailers/couplings always make lots of noise and rattle when empty. If you look at the coupling its pretty simple and you will see why it rattles so much. It really doesnt hold the ball as such, it just stops the coupling from coming away from the ball hence rattle clunk rattle clunk, yes it can be very unnerving. Very quiet with a load though.
The others and I have HR style tongues which are worse because the tongue rattles as well because the tongue isnt tight in the sleeve. And even worse is something like mine which has a mechanical brake on the trailer scares me witless sometimes.
Old 07-04-2012, 08:29 PM   #10
stev3n
Be careful not to over tighten the adjusting screw. If you have it over done, every time you do a left hand turn it will loosen the tow ball nut. I always weld the threads below the tow ball nut, been caught before. Goodluck
stev3n is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 10:25 PM   #11
au adam
au adam's Avatar
hope this helps
John
I just remove mine altogether
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 10:29 PM   #12
Mickxr8
Mickxr8's Avatar
Maybe try chucking a bit of `dead weight` on the front of the trailer ie spare tyre etc when empty ?,
"You can't fight stupid people - there's just too many of them.The internet: Access to all the world's idiots
Mickxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 11:21 PM   #13
mickbundy
A good dollop of grease in the hitch will quieten it down, Just remember to wipe the tow ball when you take the trailer off as the Missus will be ****ed if she gets grease on the clothes putting shopping in the boot. Hope this helps like I say wont stop it but will quieten it
mickbundy is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2012, 11:54 PM   #14
I assume you have a towball of a size that matches the trailer. In any event, they come in a variety of diameters in imperial and metric and it may be worth trying the next size up or the nearest equivalent in the imperial size if you currently have a metric sized one. Most current towballs are metric 50 mm but if the trailer is old it's likely a 2" or similar and that approx 2 mm difference will create the knocking.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 11-04-2012, 06:32 AM   #15
XDV800
+1
Lots of silly answers in here. Take it to a trailer specialist or a small mechanic shop, i'm sure someone would take the 30 seconds to rectify it for you without charge.
XDV800 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2012, 01:53 PM   #16
Olbucko
Olbucko's Avatar
I had the same problem, I brought 2 cheap couplers from discount auto suppliers that knocked back and forth all the time, made to fit 2 inch balls, if you adjusted them up so they didn't rattle they were hard to get off. I eventualy found a specialist parts supplier who sold a good quality 50mm coupler for about $40. No more noise!
Cast on the side was AL-KO 2000KG AS4177-3 (finished in a silver colour) Name of the supplier was Brakepro Auto Spares, 02 6352 1200 I am sure that if you paid in advance with a credit card they would send you one.
They can be trusted, I have been dealing with them for 25 years.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
