09-07-2012, 11:05 PM | #1 | ||
T&D BROS RACING
363ci Windsor T-TRIM supercharger 426rwkw / 572rwhp with 14psi on the last tune
09-07-2012, 11:27 PM | #2 | ||
Coolio
10-07-2012, 12:00 AM | #3 | ||
T&D BROS RACING
There are clips on you tube and info on the set up under T&D BROS RACING
10-07-2012, 11:25 AM | #4 | ||
Stroking it...
More details on setup would be great.. What block, internals, heads, ECU, drivetrain?
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
10-07-2012, 04:14 PM | #5 | ||
T&D BROS RACING
The dyno clip of the side rear shot has all the engine specs
It's running a microtech lt10s the factory auto rebuilt with a 4500rpm stall converter and the IRS with 4.1 mini spool and dual 3 inch stainless steel exhaust all the way through |
10-07-2012, 04:45 PM | #6 | ||
Stroking it...
For those of us who don't feel like trolling youtube for specs:
BLN 363 ENGINE COMBO WORLD BLOCK WINDSOR 8.2 DECK 4.125 BORE 4 BOLT MAINS SCAT STROCKER CRANK 3.4 INCH SCAT RODS 5.4 INCH SCAT FLEXPLATE PROBE PISTONS (CERAMIC COATED) MELINGS HIGH VOLUME PUMP HIGH ENERGY SUMP ROLLMASTER TIMIMG CHAIN ROMAC HARMIC BALANCER CLEVITE TRI AMOR MAIN AND CONROD BEARINGS SPEED PRO RINGS SOLID ROLLER CAM CRANE ROLLER LIFTERS FACTORY GT40 HEADS FULLY PORTED (CERAMIC COATED CHAMBERS) FERRERA VALVES (CERAMIC COATED) PSI POLISHED DOUBLE VALVE SPRINGS PSI RETAINERS CRANE COLLETS YELLA TERRA PLATINUM ROCKERS TREND PUSHRODS FORD RACING ROCKER COVERS EDELBROCK SUPER VICTOR JUNIOR MANIFOLD WILSON 82MM THROTTLE BODY WILSON 90 DEGREE ELBOW MSD COIL PACKS ICE IGNITION LEADS VORTECH T-TRIM SUPERCHARGER (14 PSI) VORTECH BLOW OFF VALVE PLAZMAMAN INTERCOOLER K&N AIR FILTER ARP STUDS AND BOLTS THROUGHOUT ENGINE Interesting choice on keeping the 40's, what are they flowed too? Assuming it's not running I beams and the compression is low enough, I'd be upgrading the heads to some VIC JNR's or the likes, buying a V7YSI and screwing up the boost!
10-07-2012, 05:30 PM | #7 | ||
T&D BROS RACING
Thanx for that Cam I'm new to the forums I will post pictures and more info on the car soon
I was originally chasing 500rwhp and I knew the GT40s could make that and yes they are Ported up flowing around 490hp. I am planning on a set of alloys and a pro charger but first I want to drive it and race it for a while before they go on |
10-07-2012, 05:51 PM | #8 | ||
Stroking it...
Now we're talkin! Procharger and some decent heads would be a killer combo..
Should put up some cash and become a paid sponsor of Ford Forums, i know myself (and many others) would prefer to support a company that supports Ford Forums!
10-07-2012, 05:56 PM | #9 | ||
T&D BROS RACING
How do I go about setting that up?
10-07-2012, 08:28 PM | #10 | ||
Cat be Still !!!
Welcome to the Forums............Very tough AU you have there
Just watched some of your Youtube clips..........Did I hear right, 11.90@120mph? Thanks for posting your Car. Cheers, Craig.
2002 AUIII XR8 n/a: 13.65@101.8mph. With Raptor Assist:..12.73@111.5mph. With ET Streets:......12.44@110.7mph, a one time fluke.........12.54@110mph back to back. With 3.9 Gears:.......12.40@112.5mph, still trying! Tune by XFT |
10-07-2012, 09:46 PM | #11 | ||
T&D BROS RACING
Thanks! Yes but that was with a slipping auto, with a previous setup and making 511rwhp it ran 11.2 @ 122mph getting the auto sorted out now and then back on the track and should be well into the 10s
10-07-2012, 10:54 PM | #12 | ||
Cat be Still !!!
Nice, spotted the tyre spin and did hear the commentator say 2.xx sixty foot and thought with hook on the tyres a low 11 was on the cards............And that was with the old set up hey.
Wow, some hook with tyres and auto a 10.xx is definitely in the bag!!! Craig.
10-07-2012, 11:06 PM | #13 | ||
T&D BROS RACING
When it ran the 11.2@122mph it had a 1.6 60ft with 511rwhp with 3.9 diff gears now it has 572rwhp with a 4500rpm stally and 4.1 diff gears so when it hooks up it's safe to say leaving the line at 4500rpm as oppose to 1000rpm with the gears and extra power and torque 10's is in the books, heading to the track as soon as the box is done
Your xr8 n/a is pretty quik what's done to it? Last edited by BLN363; 10-07-2012 at 11:14 PM. |
10-07-2012, 11:27 PM | #14 | ||
Cat be Still !!!
Looking forward to hear the results from your next track visit..........Keep us posted.
Thanks, Mine is a stock 220 motor with a Raptor blower pushing around 8.5 pound boost, also runs a Snow Performance Water/Meth kit for some chemical intercooling. Need to have my tune finished, bolt on some Mickey T's and see if I can get the times down a little more. Cheers for now, Craig.
11-07-2012, 08:53 AM | #15 | ||
T&D BROS RACING
You say you have run 13.6 n/a what else have you done to the engine gear box diff??
11-07-2012, 01:25 PM | #16 | |||
Former BTIKD
http://www.fordforums.com.au/member....stposter&f=293
11-07-2012, 06:27 PM | #17 | ||
MADED.6
Wow that's amazing.
572rwhp from .gt40's is ruthless. Who did the heads for you mate. Such a good bottom end with .gt40's is a little strange but 572rwhp is crazy talk Haha. The powerskid video is really good aswell. Cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
11-07-2012, 08:23 PM | #18 | |||
Cat be Still !!!
Craig.
11-07-2012, 11:43 PM | #19 | ||
T&D BROS RACING
Thanx mate
The heads were done by RACETECH in Sydney, no one appreciates the gt40 cast iron heads so I wanted to see how they'd go with a good bottom end big cam and some boost, Ofcourse il be going alloys later :-) By the way that powerskid was with an older set up running 511rwhp the new setup made 572rwhp but the auto was slipping as soon as i get it sorted il be going to the next event and giving it another go Cheers |
27-06-2013, 08:29 PM | #20 | ||
T&D BROS RACING
Just got the gearbox sorted not long ago and got it retuned it now makes 462kw/619hp at the wheels on pump fuel with 14 psi. As soon as I work out how to post some pics I will put them up
5 users like this post: |
27-06-2013, 10:28 PM | #21 | ||
That's awsome bud ! Solid setup .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
27-06-2013, 11:21 PM | #22 | ||
Cat be Still !!!
Rock solid results there bud.............
Looking forward to some action pics.
28-06-2013, 07:39 AM | #23 | ||
Need More Cubes!
A link on how to post your pictures so we can all get a better look at this machine of yours, use Method 2 Photobucket thats what I have all my pictures in and they come out looking good!
http://www.fordforums.com.au/showthread.php?t=20569 Noticed you have a 4500 Stall, what gearbox you running?
1992 EB GT 418 Windsor, T56 Magnum! Engineered/Modification Permit! STREETBUILT Racing 1993 DC LTD EB GT Drive Line! |
16-08-2013, 03:01 PM | #24 | ||
T&D BROS RACING
At the track with the new set up
4 users like this post: |
16-08-2013, 03:05 PM | #25 | ||
T&D BROS RACING
The current combo
3 users like this post: |
16-08-2013, 03:07 PM | #26 | ||
T&D BROS RACING
Last tune on pump fuel next tune will be on e85
16-08-2013, 03:10 PM | #27 | ||
5.6L x 2 pilot
Very nice! What did it run with the current on pump fuel?
Well done. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
16-08-2013, 04:00 PM | #29 | ||
T&D BROS RACING
So far 10.5@131mph but I've changed the diff gears they were too long and going out this Saturday
17-08-2013, 08:51 AM | #30 | ||
T&D BROS RACING
