Would someone be able to post up a photo of the cable/bracket and spring underneath there V8 throttle body? Just cant remember how the dam thing goes
Iv hooked it up but im left over with a spring and a small black bracket piece :/ |
#3 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
And the small bracket left over supports the square black bit of the loom, it bolts in front of the other one you can just see it in the right corner as you look at it I can get a better shot if you need it
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Reckon you could get a photo of it all installed from underneath the throttle body? Maybee one with the air intake pipe off?
Would be much appreciated |
#6 | |||
AU DIE HARD
From the front looking at the fire wall
![]() ![]() On top looking down at the back of throttle body from pass.side ![]() From driver side ![]() cable bracket bolts to rear of T/B first then loom bracket over it ![]() Underside to back of motor ![]()
perfect! thanks alot for all your help!
If this is for your T3 its different
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
