Jeep/Mercedes Technician
A while back I found out that my drivers side headlight wasn't working so I replaced it, to my surprise it still didnt work. My lights on the dash had been flickering leading up to this and now half the dash lights don't work and neither does the shifter light.
Now the left hand light also only works some of the time, I've tried buying a new headlight switch but that made no difference at all. This is really starting to frustrate me!!!! Can anybody help???
The Ride FGX XR8, Silhouette, Manual, 500HP, 940NM, Tune, 71mm Pulley, KPM Intercooler, BMC Twin Air Filter ![]() |
i`m not a sparky`s ******* , but i think i would be checking earths and wiring connections firstly old mate, then go on from there.
Where are the headlight earths normally run to? I don't know where to look!
Follow the wires back from the headlight globe holder
Got Ghia?
If you have a test light probe the plug.
If not put a bit of wire from the earth plug (should be able to poke it in the back) to the -ve battery or ground to check if it's an earth issue.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold ![]() 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
