Old 19-04-2013, 08:22 AM   #1
KR1STO
Just another mock-up..
KR1STO's Avatar
Default Fitting factory Sat Nav to AU2/3.
Hey guys,
I'm looking at fitting factory Sat Nav to an AU2 Fairlane.
Now I'm just wondering if it's all plug and play.
If I have the unit, loom and the disc player in the boot, does it all plug into the factory loom without needing anything else..?
Has anybody attempted or achieved this modification..?
Also, can you still get the current maps for the system..?
Any help is appreciated..!
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2013, 07:43 PM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default Re: Fitting factory Sat Nav to AU2/3.
Not sure about the wiring Kris, but I do have maps as of Sept 2009. PM me if you go ahead with this project.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 19-04-2013, 07:48 PM   #3
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
I haven't attempted it, but I do know the dash is physically different, so is the wiring...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2013, 08:21 PM   #4
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
It was a $5K option, so in a Lane, you would expect the wiring to be there. Actually, the wiring diagrams on here should tell you.
Let me know if you need me to take any photos Kris.
Stu
2002 AU II LTD
Old 20-04-2013, 10:53 PM   #5
KR1STO
KR1STO's Avatar
The only thing physically different in the dashboard is the centre area, which I can get. I have been told the wiring is there, I just need to confirm.
Stu
As above, I have been told it is there apparently.
Cheers Stu, if I get stuck I just might hit you up for some pics..
I'll do a little more homework and see how I go..
Thanks guys..!
see my car here:
[SIGPIC][/SIGPIC]
Old 22-04-2013, 04:54 PM   #6
robertjp
where can you get the center dash from and if you dont mind what is/was the cost.
Robert.
robertjp is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2015, 10:59 PM   #7
NCII40
XR6T BA 2002
NCII40's Avatar
I just bought a full sat nav kit with loom
i been searching around now and can't find any of the factory wiring?
anyone know where it is hidden
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2015, 06:27 AM   #8
NCII40
XR6T BA 2002
NCII40's Avatar
I just saw this on eBay and has got me thinking about installing this in lieu of the sat nav screen?
Trans temp would be better than the rpm gauge
XR6T 2002 BA
Old 24-12-2015, 10:30 AM   #9
NCII40
XR6T BA 2002
NCII40's Avatar
The 2 factory plugs behind the radio don't fit into the sat nav
Def not pre wired
XR6T 2002 BA
Old 24-12-2015, 10:32 AM   #10
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks guys..!
You gotta cut the ash tray fixing panel to fit this setup
otherwise you cant push the radio back
XR6T 2002 BA
Old 26-12-2015, 07:41 PM   #11
hellrc5
unfortunately I got no information on the sat nav plug location but if nothing works you can easily get almost all the signals required at the radio harness, at least this is where I hooked up the FG mk1 sat nav (VDO Dayton PC5200) in my AU2 falcon.
you basically need perm. +12v, switched +12v, Ground, speed signal, sidelights signal (dashboard/radio illumination) and reverse signal. you should not bother with the reverse signal unless you reverse 50 meters on a regular basis. speed signal will only be there if your car is a high specs one (eg Fairmont), if it is a low specs one like mine (Forte) you need to get the speed signal from the odometer cluster. NB you should not use the GND line on the radio harness (but rather any chassis point or the metal radio cage itself) as it can cause problems with the backlight of the tiny LCD panel of the odometer counter.
hellrc5 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2015, 09:13 PM   #12
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks for that
I have a full loom that came with the package, but i assumed fairlanes were pre wired
Its all fitted now, just no sat nav hooked up. I might sell it off and get one of those LCD gauges.
XR6T 2002 BA
Old 26-12-2015, 09:20 PM   #13
hellrc5
fairlane was definitely were pre wired so as fairmont but even the low series falcons have a dedicated sat nav fuse (monochrome pictogram only vdo dayton pc3200/pc4000 was an option while high series and ltd and fairlane used the full grown colour pc5000) but I got no idea where the plug should be and has always been lazy to trace it back from the fuse box
Old 27-12-2015, 08:36 AM   #14
TOP DOG
TOP DOG's Avatar
If you do, please let me know. I gutting my wagon to redo the interior so the wiring might be a bit easier to work out.
Graham
South of DARWIN NT
AUIII Flash Cab project (nearing completion)
TOP DOG is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2015, 09:59 AM   #15
NCII40
XR6T BA 2002
NCII40's Avatar
Cool, I will be only selling screen, wiring and nav unit though
I will still need the fascia and wood grain surround
XR6T 2002 BA
