Old 19-10-2014, 07:15 PM   #1
chocobullets
Smile 2009 Ford Focus Duratec-HE 2L Spark Plugs
hi, im not sure if there is a another post like this but, i was wondering what is the best spark plugs for a 2009 focus LV LX... so far ive seen NGk IRIDIUM, PLATINUM and stock spark plugs. What would be the best for performance?
Thanks for the help.
chocobullets is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2014, 07:41 PM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: 2009 Ford Focus Duratec-HE 2L Spark Plugs
Effectively little to choose between them for performance on that engine - the main difference between the plugs mentioned is life expectancy.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2014, 11:04 PM   #3
dazFX
I bought a set of NGK iridiums from op oils for $52 shipped when my plugs where due about year ago. I've also tried autolite 103s, but cant remember if i noticed a difference. I traded the car in a week after installing.
dazFX is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2014, 06:24 PM   #4
oemdenied
we use the NGK range.
The way we see it is if your using a plug with a shorter life expectancy to save some money, in the long run it doesn't save you money if paying a workshop to replace them as most workshops have a minimum half hour labour charge for any work.
Advertising removed.
oemdenied is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2014, 08:34 PM   #5
chocobullets
any particular spark plug, a link from ebay or a shop like supercheapauto would be nice
thank you
Old 20-10-2014, 09:44 PM   #6
dazFX
I meant Opie Oils
Old 21-10-2014, 10:07 AM   #7
chocobullets
Like what model ngk did you get
Old 21-10-2014, 04:51 PM   #8
DZFord
DZFord's Avatar
The recommended NGK plug is ITR6F13, which is the iridium plug
Cheaper to import from UK via eBay
Old 21-10-2014, 08:55 PM   #9
chocobullets
yea i got some earlier today, they made a difference from the old ones (louder exhaust and kind of faster)
