Old 21-02-2015, 01:52 PM   #1
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Default Leak Down Tester.
So my car got very hot (into the red, just) I brought a leak down tester in hopes of confirming blown head gasket or not.
So got a Toledo leak down tester, all cylinders are all right with no bubbling through coolant. However it seems the regulator on the tester limits pressure to 50 PSI. Will this be enough to show a blown head gasket?
Thanks,
Brad
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2015, 02:15 PM   #2
MrEL
Sick Puppy
MrEL's Avatar
Default Re: Leak Down Tester.
Leak down tester wont help with a head gasket.
They are for checking rings , valves etc.
You need to get a C0 test done for a head gasket.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2015, 02:43 PM   #3
99AUXR
Brad
99AUXR's Avatar
Interesting all leak down testers I have seen have on the packaging head gasket test and there are heaps of videos on YouTube but some of the testers went up to 100 psi.
Old 21-02-2015, 08:54 PM   #4
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
I'd be looking at other things for an overheat before head gasket. Does the fan work? Fluid level? Hoses all okay? What sort of driving were you doing at the time?
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2015, 09:03 PM   #5
99AUXR
Brad
99AUXR's Avatar
Fans weren't working overheated at idle when wasnt in the car. Retarding timing and all, used one of the fluid testers that you put on top of radiator and suppose to detect combustion gases. Only issue is when car is shut down I can now hear the top hose bubbling, when running its fine.
Old 22-02-2015, 07:16 PM   #6
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
Stuck thermostat?
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2015, 08:11 PM   #7
99AUXR
Brad
99AUXR's Avatar
The car doesnt over heat when driving though, all is fine now the fans are working? Temperature stays in the normal?
Just this bubbling sound on shut down?
Old 22-02-2015, 09:04 PM   #8
simon varley
you may just have air in the system from when it overheated. Run the degas part of the fill procedure to clear the air. I'm not sure what it is for this, but get the car hot and give it some revs. Should be info on line.
Old 01-03-2015, 02:01 PM   #9
99AUXR
Brad
99AUXR's Avatar
So wasnt using any coolant until yesterday. Found the problem loose hose clamp.
