BA Mk2 Fairmont
We have a LT and the parking sensor has been playing up. It beeps when not even close to an object and sometimes just has a constant beep. I disconnected the looms and tried connecting one at a time but couldn't find the issue.
What else can I try to test the sensors? What can I use to clean the looms? Wd40? |
I assume its aftermarket sensors. Have you checked the control box into which the sensors are plugged is not stuffed. That is the most likely cause if all sensors have the same issue.
