Old 01-06-2016, 08:07 PM   #1
natedogg1986
Default au auto trans
has anyone experienced slipping in 1st gear out of the BTR 4 speed.
I have noticed it doing it intermittently the last week. Happened 2 or 3 times now.
Any ideas if it might be a solenoid issue or clutches/bands in the trans?
2003 BA XR6 N/A SEDAN IN ACID RUSH
CURRENT MODS: PACEMAKER 4490's, 3 INCH HIGH FLOW CAT, F6 CAI, K&N PANEL FILTER
FUTURE MODS: CAT BACK EXHAUST, MAG WHEELS
natedogg1986 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2016, 06:57 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: au auto trans
Could be C2 clutch but check fluid level and fluid condition as a starting point.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2016, 09:05 AM   #3
falconhell74
falconhell74's Avatar
service the trans and add lucas stop slips its brilliant stuff , it rejuvenates seals , deglazes servos & helps rejuvenate old oil
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2016, 06:20 PM   #4
natedogg1986
thanks for the reply's, can you tell me which solenoid controls the c2 clutch?
Old 03-06-2016, 07:33 PM   #5
OzriderXR8
OzriderXR8's Avatar
Aren't these sealed at the factory?
I didn't think I could do mine at home, I want to do a flush and replace all fluids.
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Rover P5 3 Litre Mk1
OzriderXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2016, 10:50 AM   #6
natedogg1986
the transmission is not sealed and can be serviced.
Old 05-06-2016, 11:30 AM   #7
Blue Shadow
R.I.P. Maggie
Blue Shadow's Avatar
They called it a sealed trans, but you can change & top up ATF and filter.
AUII XR8 200Kw Ute
FG XR6T
1976 289 Mustang (Gone)
Blue Shadow is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2016, 05:26 PM   #8
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: au auto trans
Have you used this a Lot? did you use the whole bottle?
UK
Old 05-06-2016, 05:54 PM   #9
falconhell74
yes I have used it on many vehicles over the years .
You use the full bottle its like a honey consistency .
I once used it on a old HG ute that had lost all drive , dumped the old oil and used 2 bottles in it , she went ok after with only minimal slippage at high revs , just needed to get it from a to b as it was a project , so I know first hand many times over that it is good stuff , it is also recommended for use in new transmissions for longer life .
Get a trans service kit drop the old oil , put in the new filter and pour it into the pan before you bolt it back on then fill with trans fluid.
Xc falcon
Previous fords-
Old 12-06-2016, 04:30 PM   #10
natedogg1986
UPDATE
After some reading through the workshop manual, I decided to replace the 6 solenoids that are mounted in the Valve body as well as do a service.
Bosch solenoids were purchased and all was set to be replaced.
On removal of the pan, no metal or clutch pack material was found and fluid colour was good.
On inspection of the solenoids I purchased, there were 2 different part numbers of the on/off type solenoids. The ones I purchased matched the s1 and s2 but not s2,s4,s6.
After some research on the net I could not find an answer as to the difference so I just replaced the s1, s2 and s5 solenoid.
I also replaced the O-rings on the front band servo as a preventive measure as some dust was sticking around the sealing surface, indicating minor weeping.
Does anyone know the difference between the on/off type solenoids???????
Old 12-06-2016, 06:14 PM   #11
gregaust
The solenoids are all the same . The C2 clutch is the forward clutch and is hydraulically controlled from the manual valve . Solenoids don't do everything .
Easy way to remember
S1 + S2 do all the shifting
S3 + S4 are for shift quality , I.E smooth shifts
S5 is the variable pressure solenoid and is different to all the others as you prob know .
S6 is the cutback , that drops line pressure as road speed increases
S7 is for lockup converter
Old 12-06-2016, 06:19 PM   #12
See page 5 of this http://www.pertheseries.com/other_fi...(EAII-EF1).pdf Noting on later (AU onwards) transmissions they went to all being normally open On/Off solenoids except the VPS solenoid.
But likely other parts of this document will also be of interest to you.
Old 12-06-2016, 07:01 PM   #13
George V
As per previous posts, all solenoids except S5 are identical.
If your auto was slipping only recently, especially in recent cold mornings during first start up / first bend, the it may be due to low oil level.
Check your stall speed in D and in reverse, if C2 is slipping then stall speed in D will be high (above 2200rpm).
There is a very good thread by Jonydep on servicing autos.
Regards,
George V
George V is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2016, 07:47 PM   #14
natedogg1986
All the information I could find said they were the same but if that was the case then why would there be different part numbers?
Only thing I could think of was that the position of the valve in the solenoid was different between the 2 types.
IE: Brown - Open normally, Closed when energised.
Black - Closed Normally, Open when energised.
Old 12-06-2016, 07:56 PM   #15
natedogg1986
Think I found the answer.
Page 6 in the link below talks about normally open and normally closed.
Anyone confirm?
Old 12-06-2016, 08:14 PM   #16
gregaust
They're the same
Old 12-06-2016, 08:27 PM   #17
natedogg1986
Thanks for that,
How do they achieve the normally open/normally closed differences?
Old 12-06-2016, 08:53 PM   #18
gregaust
Not sure what they are on about there re NO vs NC . The solenoids are the same . You cannot swap a NO + NC , just won't work
The only difference I have come across is most use a plastic body solenoid . Some , I think around EB use a metal body solenoid that i don't think interchange
Only other differences in valvebodies is up to AU or thereabouts the solenoids earth individually , BA on they earth back to ECU
Old 12-06-2016, 09:01 PM   #19
natedogg1986
Are you able to find any information on these numbers? May shed some light on what they are talking about in the manual.
0 260 120 017
And
0 260 120 029
Old 12-06-2016, 10:21 PM   #20
Prior to the AU the BTR had two types of solenoids in addition to the VPS ones. The normally open (NO) solenoids allow fluid to flow until power is applied to them they close cutting off the fluid flow. Normally closed (NC) solenoid allow no fluid flow until power is applied. Power when applied activates a copper wire coil creating a magnetic force that moves a plunger inside that coil in or out opening (NC) or closing (NO) the valve.
Like this:
or this https://www.youtube.com/watch?v=lPTtxBVpKH8
The two types (NO and NC) are not interchangeable. From AU onwards they are all normally open solenoids and are interchangeable.
EAs and a few early EBs had metal bodied solenoids but all since the ED have been plastic bodied.
Old 12-06-2016, 10:37 PM   #21
0 260 120 017
And
0 260 120 029
Ford part numbers are EF 640070 A1 or EF 14003 2 A1 (e.g. http://www.ebay.com.au/itm/GENUINE-F...UAAOSwLzdWSHo4 ) so those numbers mean nothing to me. What manual; Ford factory or aftermarket?
Old 12-06-2016, 10:59 PM   #22
Note that officially all after the EA were plastic bodied solenoids but I have seen them in EBs and later cars albeit as they were not cars with know histories they could have been retrofitted replacement spare parts. And to correct myself, it was also from the EB (not the AU) onwards that they went to all being normally open on/off solenoids.
Old 12-06-2016, 11:03 PM   #23
natedogg1986
Thanks for that. The part numbers are the Bosch numbers on the solenoid.
When going this exercise today, s1,s2 were 0 260 120 029. Brown bodied.
s3,s4,s6 were 0 260 120 017. Black bodied.
I have compared the two and there is external differences in them, but oviously cannot see inside.
As you can see from the above image, you can see the differences I am talking about.
I also noted the ba range has 1 more brown type and 1 less black type. Which I find interesting.
Old 12-06-2016, 11:20 PM   #24
0 260 120 017
And
0 260 120 029
Ok the answer is here http://muadiller.com/Ureticiler.aspx...cturer?page=10 they are Bosch part numbers.
0 260 120 029 = EF 640070 A1 as BTR trans solenoid
0 260 120 017 = FORD 0585640029 and I am not sure what that fits.
Old 12-06-2016, 11:23 PM   #25
It's likely the two types are interchangeable but I don't know. This thread would suggest they are http://www.fordforums.com.au/showthread.php?t=21444
Old 12-06-2016, 11:29 PM   #26
natedogg1986
It is interesting that if there is no difference between them, why were they used. I'm sure there would be a reason for it, but no one seems to know.
When Tuesday comes around I might ring ford and motorspecs and ask the question of them.
Old 12-06-2016, 11:30 PM   #27
This would suggest that the brown ones are new improved design http://www.ebay.com/itm/Ford-EF-EL-A...-/350321482521 that other thread also had the black ones as the ones that failed. I seem to recall there was a redesign of involving the mesh screen/filters as they were a cause of seized solenoid on earlier transmissions. Were the mesh screen a separate part on black ones but integrated on the brown ones? I have some recollection on having to remove a seperate mesh screen from the hole before inserting the later model solenoids; or was that the other way around? Or perhaps the mesh screen became easily detached from the black one. Or maybe Alzheimer's has hit me and I am imagining things again.
Old 13-06-2016, 07:38 AM   #28
natedogg1986
Old 13-06-2016, 07:39 AM   #29
natedogg1986
You can see the differences on the ends of the solenoids.
Old 13-06-2016, 08:02 AM   #30
Yes; but this reinforces my questionable memory that the early black ones may have had separate mesh screens you had to be sure to remove when replacing them with the brown ones with integrated mesh screens.
