RBS
Old 22-07-2017, 02:44 PM   #1
Bob pasut
Default Ecu drama
I have a auII Ute dedicated gas 4.0lt auto. I have a faulty ecu. I am unable to find a 12nd ecu under $350 exchange.
Will a 12LD ecu which is $50 be any good ? It has the same "ETV-735" module ID, and is for auto, gas, 4.0lt and Ute.
Bob pasut is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2017, 03:10 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: Ecu drama
Yep, give it a crack, your Au is the same series as
the Falcon the ecu come out of, good luck should work afaik.
See if you can return it if the ecu doesn't work though for whatever reason.
cheers, Maka
Old 22-07-2017, 03:40 PM   #3
Bob pasut
Does anyone know if the BCM will communicate with this similar ecu ?
Old 23-07-2017, 03:04 PM   #4
undertow
Technical Contributor: For members who share their technical expertise. - Issue reason: AU Aux input HOW TO.
It will need a PATS (security) relearn... you can do this with forscan.
https://fordforums.com.au/showthread.php?t=11462244
undertow is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2017, 10:13 AM   #5
Bob pasut
I have tried to reconnect a new second hand closely matchting ecu today. I tried to do run PATS program on the free forscan program but it wants me to pay for a licence. What should I do ?
Old 09-08-2017, 06:08 PM   #6
rmack
rmack's Avatar
Pretty sure the Extended license is FREE just need a active FORScan forum account. (WINDOWS VERSION)
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
