Old 15-09-2017, 09:18 PM   #1
JRH342
Pursuit 250
JRH342's Avatar
Default Pursuit 250 Headlights flickering then stopped workig
I would to the headlights on & they would come on then flicker once or twice then stay on as normal.This happened a couple of times during the week then tonight i turned them on they flickered once then didn't come back on.I'm thinking switch.Whats the easiest way to test the switch ?
Any suggestions would be helpful.
CHEERS
HODGIE Pursuit 250
JRH342 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2017, 02:12 AM   #2
jpblue1000
jpblue1000's Avatar
Default Re: Pursuit 250 Headlights flickering then stopped workig
Globe!
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2017, 08:29 AM   #3
foxtrot3
foxtrot3's Avatar
Hi. Could be the circuit breaker in the under bonnet fuse box. Get yourself a test light and check to see if you have power on 2 terminals of both the high beam and low beam relays. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2017, 07:49 PM   #4
JRH342
Pursuit 250
JRH342's Avatar
Hey guys swapped a couple of relays around & found the problem.
The head light relay in the engine bays.
Thanks for your replies.
HODGIE Pursuit 250
