Old 16-10-2005, 11:33 AM   #1
nath-efxr8
Default 20" wheels on a EF XR8
Hey guys,
Does anyone know what is required to fit a set of 20ies on a EF XR8?
What width would be needed for the correct load rating? (235/245????)
I'm guessing coilovers would be required on the front and guards rolled at a miminum...
Thanks
Old 16-10-2005, 11:41 AM   #2
WizBang
Why , when a 18" looks so good with the right rubber , but if size matters I think you are yp for alot work
P.S Welcome aboard
WizBang is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2005, 11:45 AM   #3
parawolf
beep beep
don't forget that engineering certificate
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2005, 05:39 PM   #4
bindi
Redhead extraordinaire...
bindi's Avatar
And don't forget the penis pump... it's a cheaper way to get some size happening in your pants than 20" mags mate!
Ach, just kidding, welcome! :
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2005, 05:45 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
pm gmkilla hes got 20inch rims on his car.... up from 19's
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 17-10-2005, 02:40 AM   #6
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
get 20"s there sick!!!!!!!!! and alot of people will tell you otherwise on these rice free forums
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 06:59 AM   #7
Mike Gayner
Mike Gayner's Avatar
Whats the point in 20 inch rims? They look stoopid.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 10:04 AM   #8
BlackLS
20 inch rims will have the bling factor, but on a E series falcon, even when lowered, you can't get that "slammed" look that a nice set of 18s and dropped will get ya. Plus the largest wheel that came out of the EF series was the optional 17" on the XR? That means you can only go an inch over (18") without the fear of being defected.
There are a host of other things ie tyres are cheaper and wider range, 20's will throw your speedo out, car will be substancially slower than a car with the same rolling diameter rims as stock. Even the added weight will make the car more sluggish.
Bah, who am I kidding, I wanna see an EF on 20s. Just concider the above
Old 17-10-2005, 10:20 AM   #9
parawolf
beep beep
Hence my comment, don't forget your engineering certificate.
Old 17-10-2005, 10:22 AM   #10
AdzT3-146
own the road
AdzT3-146's Avatar
Agree with what ArgonEF said, except the only time the 17" were available were on the EL GT's and i think the EB GT's. all XR models had optional 16" only.
so unless you have a GT then the biggest you can legally go is 18".
T3 TE50 #146
Originally Posted by UNR8D
Id rather date a goat with syphilous then drive a maloo.
AdzT3-146 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 11:38 AM   #11
trikee
overdriven
well actually its not like this at all.
you can go whatever size wheels you like as long as it doesnt increase in overall standing height by more than 15mm or 15%. cant remember which one.
and you cant increase in width anymore than 26mm each side of the car.
so go for it.
dont let anyone fool you with size legalities
trikee is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 03:18 PM   #12
M&Ms
M&Ms's Avatar
so go for it.
Just a correction; you can put whatever size rims you like but the overall diameter of the wheel/rim package must not be more than 25mm more than or less than stock.
You are correct about the width, 26mm
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 03:33 PM   #13
PH47
Ford Power, in a Merc?
PH47's Avatar
DOWIT!
Worry about hurdles when you get to them
PH47 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2005, 04:14 PM   #14
Polyal
The 'Stihl' Man
Polyal's Avatar
20's...lol
19's look bad enough on some e series. I dont understand why people think bigger looks better. Its got alot more to do with the suspension set up than anything. Most 17's look great with the right spring. Hell ive got 16's and they dont look bad at all.
  • 1973 ZF Ford Fairlane
