Old 26-11-2005, 05:36 PM   #1
Barry_v
rocknrolla
Barry_v's Avatar
Default AFF National Dyno day graphs (D/U beware)
didnt want to clutter up the general discussion thread with big pictures. please everyone post their sheets.
DC LTD 5.0
stock 230k bottom end
Pro Products Typhoon intake with phonelix spacer
Crane 2030 camshaft
home ported E7 heads
genie extractors
65mm tb
70mm Pro-M maf
FMS underdrive pullies
ZC Fairlane 351w
autolite 4300 carb (stock)
cast iron manifolds (stock)
etc.
Barry_v is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 05:38 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
EL Fairmont 6cylinder
4.0L 6cyl
Stock 160km bottom end
Wade 1521a
Pacemaker PH4480
Redback exhaust
*yibbider yibbider thats all folks*
Old 26-11-2005, 05:46 PM   #3
XRchic
Hello
XRchic's Avatar
Sorry, we dont have a scanner, so this is the best we could do with the digicam.
2008 FPV TERRITORY F6-X
Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes.
: Cobra :
XRchic is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 05:59 PM   #4
joshf2
striped
joshf2's Avatar
2005 fiesta
7000k's on the clock
2" cat back with no centre muffler and straight through rear muffler
GT stripes
joshf2 is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 06:32 PM   #5
Stampy
[IMG][/IMG]
Old 26-11-2005, 07:08 PM   #6
melbzetec
Old enough to know better
melbzetec's Avatar
Well done Stampy. I think your ST170 result will give you "National Champion" in Class 1.... but I was closer than I thought I'd be! (75.3 fwkw in the Zetec)
Old 26-11-2005, 07:31 PM   #7
Stampy
(Approx 89 Front wheel KW for my ST170) i was a bit disapointed at first but it was very hot in the shed ,but i guess we all had the same problems , I would love to see 100 KW but i guess that will cost a fair bit.
Old 26-11-2005, 08:04 PM   #8
melbzetec
melbzetec's Avatar
I thought the Dyno Dynamics dynos were supposed to automatically adjust for variations in temperature when in Shoot Out mode.
That's why they claim you can compare a Dyno Dynamic Shootout from one operator, or on different days, to the next.
Mind you, mine pulled 75.3 today, and 77.7 on another Dyno Dynamic dyno in Collingwood last week
Old 26-11-2005, 09:33 PM   #9
cogdoc
I don't think so. As Steve at RDP explained to me today the inlet temp (IT) and the ambient temp (AT) effect HP on different days. My last run at RDP was 315HP at 20 AT 18 IT and today 309HP at 26 AT and 34 IT. As the inlet temp was hotter, the HP was lower.
http://www.carformance.com.au/
cogdoc is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 10:04 PM   #10
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
When I did my 410hp run the inlet was 67 degrees and the room was 31.... last dyno day when I turned 325 it was 53IT and 23RT. The XY really suffers on intake temps on a dyno because the bonnet goes up and suddenly the shaker is being fed hot air off the radiator...
I'll try to post my sheet tomorrow or monday
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 10:13 PM   #11
melbzetec
melbzetec's Avatar
"Atmospheric conditions have an enormous effect on engine power. An engine will invariably make more power on a cold day than a hot day. In order to standardise power measurement, you need to correct for atmospheric conditions. ShootOut mode locks parameters within Dyno Dynamics Atmospheric2 (ATMC2) so that the operator cannot disable or change them. The instrumentation system adjusts (corrects) power measurements for a benchmark ‘standard’ day. ATMC2 ensures that the results are statistically adjusted for cold or hot day tests The test conditions are printed out on the graph for added validation
when comparing two power graphs. "
From http://www.dyno.com.au/shootout.htm
In Melbourne, I don't think they were measuring intake temp, just ambient temp, as there were no sensors being put into the air intakes (I have had a couple of dynos done previously on a Dyno Dynamics dyno in shootout mode and a sensor is placed in the intake)
The whole idea of Shootout mode is that any two graphs from different operators can be compared. That's why I don't understand why the suggestion that the different conditions were effecting the results. Dyno Dynamics shootout is supposed to statistically adjust the results.
No issues or complaints though. A terrific day, well organised
Old 26-11-2005, 10:24 PM   #12
Stampy
Well it seems all charts show shoot out mode but in QLD we most definitely used intake and air temp.
All together a great day no complaints. Just enhancements to come.
Old 26-11-2005, 10:31 PM   #13
jonbays
TL40 Wagon?
Unfortunately you can't believe what manufactures write about the product 100%.
The temp does make a difference. And I don't see the compensaton working.
Today in NSW I ran a 139rwkw vs 144rwkw on the same dyno same mods different fuel only.
The 144rwkw run was at Pressure 101 Humidity 41% Temp 19 degress.
Today The 139rwkw run was at Pressure 100 Humidity 49% Temp 29 degress.
Am I surprised no!
Old 26-11-2005, 10:56 PM   #14
fairmont1998
fairmont1998's Avatar
EL Fairmont 5.0
stock 108k HO Windsor
3" cat back Lukey zorst
70mm AU MAF
EL GT snorkle.
I'm pretty happy with that result.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 11:16 PM   #15
DOC
DOC's Avatar
Sorry for the poor quality pic, i went with no expectations ( this time ), and i suppose am really new at interpreting this data but i will learn as i go.
CAI
EXHAUST
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2005, 11:28 PM   #16
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by joshf2
2005 fiesta
GT stripes
Shame we cant break it down more. Id love to see how much those GT stripes gained you.
2024 F150 XLT
Old 27-11-2005, 09:45 AM   #17
cogdoc
A bit of ridicule no doubt?
Old 27-11-2005, 10:14 AM   #18
Gammaboy
Gammaboy's Avatar
I'll have to go again once the stripes are back on my beast...... see what they're worth.
Old 27-11-2005, 10:42 AM   #19
joshf2
striped
joshf2's Avatar
well considering it was run with the aircon on (i cant believe i forgot to turn it off) and its only got 74kw at the fly, i guess they must be at least another 10kw
Old 27-11-2005, 01:07 PM   #20
xr8ute
Back on the road
xr8ute's Avatar
AU1 XR8 auto
stock bottom end (190K)
Crane 2030 cam
Crane Springs
YT Stealth 1.6:1 RRs
Pacemaker 4-1 Comp
XForce 2.5" Cats
Lukey 3" catback
Modded airbox
Dave
Old 27-11-2005, 03:11 PM   #21
SSBUB
SSuper SSpy
SSBUB's Avatar
Heres mine
Series 1 VX SS A4 - 110k
MODS:
Genie tri-y's
opened cats
mail order edit
The exhuast is a stock vy ss hence a lower number than what i was expecting...but the misses likes the car quiet and she drives it half the time so im under the thumb :
Next is an OTRCAI and that should see it over 200.
SSBUB is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 03:24 PM   #22
Gammaboy
Gammaboy's Avatar
Here's mine:
Old 27-11-2005, 03:32 PM   #23
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
I'll be posting mine tomorrow. Gotta get off the Net, the phone needs using.
Carless
Old 28-11-2005, 07:19 AM   #24
TheSneakiness
Adapt or perish...
Posting up...
GAS
PETROL
Carless
Old 28-11-2005, 09:02 AM   #25
Des
V8 Rock'n'Roll....
Des's Avatar
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
2003 BA XR8
Bog Stock
[IMG]C:\Documents and Settings\Gibsonb\My Documents\Mine\My Pictures\Dyno 006.jpeg[/IMG]
1 owner 03 BA XR8 Manual Sedan
208.8 rwkw stock, update soon
20x8.5 fr 20x10 rr
Rumble thanks to:
Sureflo Exhaust - Stainless Cat's & 3.5in single catback system
"Tell 'em the guy with the Blue Mohawk sent Ya"
Des is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2005, 09:31 AM   #26
Des
V8 Rock'n'Roll....
Des's Avatar
Originally Posted by Des
2003 BA XR8
Bog Stock
Sorry, here's the pic....
20x8.5 fr 20x10 rr
Rumble thanks to:
Old 29-11-2005, 10:57 AM   #27
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Here's mine from saturday
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 10:16 PM   #28
cogdoc
"Bent Falcon" :hihi:
Old 30-11-2005, 12:34 AM   #29
Gammaboy
Gammaboy's Avatar
At least I have a sense of humour about it all :P
Old 30-11-2005, 10:53 AM   #30
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
Kinda poor for a forced induction V8, but suprisingly this is about right. Stock motor (including standard EF V8 exhaust manifold), powerdyne blower - appears to be running at about 7psi.
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
