Old 27-11-2005, 12:36 PM   #1
xespac
xespac's Avatar
Default A Place To Drive With No Rules!
Hey,
Does anyone know where I can take my car for a test drive, it is unregistered... Like is there a race track I can pay $150 or whatever but I don't have a CAMS License... I chopped my car exhaust all the way back under the drivers seat... sounds like a truck lol ... I want to test drive it before I get another exhaust....
thanks
xespac is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 12:38 PM   #2
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
why not just take to the drags.. 400 meter drive.. a helmet and over flow bottle...away you go..
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 12:40 PM   #3
xespac
xespac's Avatar
Which one? and do I need a cams license? (which I don't have :()
Old 27-11-2005, 12:44 PM   #4
SpoolMan
SpoolMan's Avatar
all you need for heathcote and calder is $40 or $55, you must have a car licence, helmet, over flow bottle and brakes that work....
Clader Friday Nights, Heathcote most Sundays..
[SIGPIC][/SIGPIC]
Old 27-11-2005, 12:46 PM   #5
xespac
xespac's Avatar
Ok thanks, does I need a full license can I get on with P's or L's? thanks
Old 27-11-2005, 12:50 PM   #6
SpoolMan
SpoolMan's Avatar
P platers are OK...
[SIGPIC][/SIGPIC]
Old 27-11-2005, 12:55 PM   #7
xespac
xespac's Avatar
Ok thanks, I will check it out ... only problem I gotta look out for is my engine mounts lol either the engine is shaking bad because it's cold or that my exhaust is the problem :P we'll see.. thanks =)
Old 27-11-2005, 08:37 PM   #8
xespac
xespac's Avatar
Before anything bad happens... would someone be able to tell me if having like an exhaust goin from engine and ends just inline with the rear driver seat would strain the engine? i'm mainly concerned that I could brake an engine mount or something? anyone had any experiences with this? thanks
It is a standard exhaust on the XE Spac 82
Old 27-11-2005, 08:40 PM   #9
Racecraft
they call me Tibbo
Racecraft's Avatar
nope dump pipes wont hurt engine mounts
Old 27-11-2005, 08:41 PM   #10
xespac
xespac's Avatar
my exhaust is like under 4 metres long lol... and a dump pipe - that's the thing like a tip where it faces to the ground? thanks
Old 27-11-2005, 08:44 PM   #11
GasoLane
Former BTIKD
GasoLane's Avatar
If it ends under the car and not on the outside of the car make sure your fire extinguisher is full !
Old 27-11-2005, 08:48 PM   #12
xespac
xespac's Avatar
lol I don't have one yet but I will seriously get one... the end of the exhaust is well clearence of the under body of the car so the only thing will get really hot will be the exhaust HOPEFULLY...
I chopped an exhaust on my old XF Falcon... but left 1 muffler (so basically the muffler was like a tip... - just infront of the diff axle) and when my bro's car needed a new engine we went to take the engine out of the XF and it had 1 broken engine mount (although the thrashing I gave it over hills and burnouts etc... could of contributed to the problem :P)
Old 27-11-2005, 08:52 PM   #13
GTS_300_Coupe
Mandy Moore FTW!
GTS_300_Coupe's Avatar
There's this place called the AUTOBAHN in Europe. I heard its a long strip of road about 10km long that you can take your car there and go as fast and as hard as you want without getting in trouble with the law.
GTS_300_Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 08:56 PM   #14
xespac
xespac's Avatar
Unfortunently the only place I think is NT in Aus - and besides... my car isn't registered YET so I cannot legally drive on the road... so that is why I was asking where I can drive on a track, like at calder or heathcote without having a CAMS License.
Old 27-11-2005, 09:31 PM   #15
RegSpec
RegSpec's Avatar
You dont need a Confederation Against Motor Sport (CAMS) licence to go drag racing. Drag racing is not controlled by CAMS , Thank God. :Reverend:
Might be in trouble with the exhaust though, some tracks have noise limits in place so check before you travel.
06' BF XR6T manual sedan in Bionic Blue.....written off 08/15......greatly missed...
New ride....07' RSpec manual Typhoon in Winter White....factory sunroof, Premium sound, Process West intercooler, upsized tubing, valve springs, 1000cc injectors, Delphi intank pump,*modified turbo, 4" dump, 5" cat, dual 2 1/2" Xforce exhaust, Mal Wood Opt 5 clutch, Herrod shifter, Ozrace coilovers with adj. Whiteline bars, 6 spot Brembos,
Edit by Crescent Motorsport.....382rwkws @ 1150nms on E85....
RegSpec is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 09:47 PM   #16
EL XR8
EL XR8's Avatar
If you're worried, go to Heatchote, they'll let you in, plus its 5 times better than Calder.
Its just a little bit of a drive. They guys there are pretty laid back, so i'd almost guarantee you'd be right to drive, as full drag cars are allowed, they hardly check over them up there!
They said if the boss wasnt there on the last day i went, i could've done doughnuts down the strip and bagged it up the whole way down (at the end of the day with no one else running) They don't mind it up there!
EL XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 10:32 PM   #17
MO
MO's Avatar
Hey,
thanks
Might I suggest you get yourself an education in the art of tuning motors before you rush off with an ill tuned(cut exhaust)motor you will lose more than you gain because you have altered the back pressure.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 10:40 PM   #18
RegSpec
RegSpec's Avatar
Laid back is one thing , safety is something else!
How would you like to be in the lane beside him if he doesnt have his act together, or his car is unsafe, he shouldnt be on the racetrack.
As far as doing doughnuts down the strip just because the "boss" isnt there,
I wouldnt think that is such a good career move to be honest!
Old 27-11-2005, 10:46 PM   #19
MO
MO's Avatar
Agreed!!
FORD RULES OK
Old 27-11-2005, 10:51 PM   #20
xespac
xespac's Avatar
I don't think I gave an impression I was going to be DRAGGING OTHER PEOPLE OFF AT THE DRAG TRACK! WOW.... I basically going to a drag track so I can see how I can go and what difference it will make power increase or not... I already know my car has way less power then it should, it's not even tuned properly and needs a service... etc....
Do you think I don't already know about an engine running differently when you change/dodgy an exhaust up? hmm...
Thanks to the people that gave positive replies and not to just post to get your post count up... =)
Old 27-11-2005, 10:56 PM   #21
MO
MO's Avatar
I'm not in here for a post count...check other threads 95% in bar no count...and I stand by what I said.!!!!!!!
FORD RULES OK
Old 27-11-2005, 10:59 PM   #22
xespac
xespac's Avatar
Anyway I didn't mean to go agro I just lose it for no reason.... anyway what makes you think i'd crash into your car SOMEHOW at the drags just because of a chopped exhaust? that is the only thing i've done to the car that won't pass a roadworthy =)
I already know about the engine obviously running a bit different, the smoothness of it idling basically the same (hardly notice it any different then it was with standard exhaust) only REALLY loud... it is deffening ... the engine doesn't stall and still idles good...
It's not like I pulled my steering column out and forgot to put it back in lol :P
Old 28-11-2005, 02:20 PM   #23
xr8edute
Thats right baby X-rated
xr8edute's Avatar
sorry to be a downer maybe but i think you would be better off spending your time and money on getting your car properly serviced and roadworthy then worrying about what difference an exhaust can make.
Get the best out of your engine then change your exhaust. It aint that hard to drop your exhaust off at the the track for a run or two.
Well thats my opinion....take it or leave it.
cheers
If Im going to hell Im going in a Ford!!! :eclipsee_
RIP The Gentleman, Peter Brock 1945-2006
I cant believe they demolished that fatefull tree!!!
xr8edute is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 09:38 PM   #24
clontarf_x
Yeah, no offence but why would you wanna take a car with effectively no exhaust to somewhere you can legally go fast?
Is it just me or does the whole concept make no sense :/
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 09:50 PM   #25
MO
MO's Avatar
You are not alone!
FORD RULES OK
Old 29-11-2005, 10:17 PM   #26
xespac
xespac's Avatar
Put it as an "EXPERIMENT" ... lol ... "If ya never, never go, ya never never know!" ???
