Peter Car
Reading the Carsguide today and noticed the Alloytec V6 has dropped to 172 kw, down from 175 with the switch to Euro III compliance. Holden did a good job of keeping that quite. Not much difference but quite suprising considereing how high tech the Alloytec was supposed to be for it to drop power due to new emissions regs. Has been a bit of a letdown after all the hype. Will they get it right for VE. The delay for VE must have really stuffed up their plans as it should have been bought out in Euro III spec to start with in VE. Will the VE live up to the hype.
yeah i also read that today. I find it somewhat confusing as the new Alloytech was suppoed to be the "new generation" of holden 6cyl engines. Surely when they brought it into the VZ series EURO III was on their minds, and if so being the 1st generation of this engine why wasnt it made compliant from the start, would have made more sense considering it was replacing a motor thats some 10 years old now.
windsor user
*/me signs up to thread out of interest*
Adapt or perish...
*Subscribed*
Carless
#5 | |||
Peter Car
I also was suprised at the news and checked the Holden website and on the specification section of the commodore range i notice in small print:
All power figures rated were based on Premium Unleaded Fuel also making it more confusing is they advertise 190 Kw and 175 Kw (now 172Kw) on normal unleaded. I always thought of Holden as very tricky in their advertising campaigns. |
#7 | |||
Remember 297 Hkw = 305 Fkw......... |
#8 | |||
Performance moderator
![]() Join Date: Feb 2005
Buick did away with it years ago... In Aussie yes...
#9 | |||
So which one is which, would FPV 290 vs HSV 297 Which type of kw should we be looking at, this is getting more confusing. |
Those ECE and DIN readings are rubbish anyway. The ford engines have more power even.
This has been proven in Motor Mag. they did a comparative test. |
#11 | |||
what the hell ??? ![]() |
#12 | ||
![]() Join Date: Dec 2004
Cool, its as powerful as my SOHC 1998 VCT motor.. when its got a bad factory tune.
Yay for Holden!
Yeh i noticed it a few months back when Holden did that VZ2 press release thingy before xmas. The higher tune 3.6 V6 is still at 190 KW although it has dropped from 340 Nm to 335 Nm. Makes you really commend Ford on their efforts to not only hold the same power levels, but to increase them slightly too (182 -> 190 KW).
#14 | |||
#15 | |||
What that translates to is that when Holden states that the LS2 is 297kw in the Ford equivalent it would be 305kw. Which also means that if Ford quote 290kw then in reality its closer to 282kw. But... just to confuse matters, the Holdens have tended to read much lower rwkws on the dyno for their respective engine outputs and the Fords tend to read higher. Motor compared a GT Falcon with a LS2 Clubby and the GT made over 240rwkw (which indicates closer to 310kw engine power) and the Clubby made 225rwkw which was bang on what it should have made. Someone may correct me. ![]() What I have found in my travels is that the standard V8 and I6 make less power than what they are supposed to (which is why they usually feel flat), and the XR and FPV motors tend to make more than they are supposed to. This is certainly the case with the FPVs and me thinks the XR6T has always a little torque happy around 3500rpm and is making closer to 470nm mid range and is not as flat as it should be. Hence why it makes similar numbers on the dyno to the XR8 and is always much quicker on the road. |
#16 | ||
The VZ hire car we got for the Springnats was a torque-less piece of crap.
#17 | |||
Last warning
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#18 | |||
#19 | ||
Force Fed Fords
The bog stock V6 comedydore engine lacks one thing needed in a large Aussie 6 and that is torque. Makes a lot of noise though.......
2021 Focus ST-3 Mountune Enhanced |
#20 | |||
buickman
The alloy Buick mtrs were sold to Leyland to power the Rover's in th 60's & 70's the 3.5 ltr alloy mtr. The 3.8 even fire mtr that was used in the VN-VY Holdens was a 2 cyl cut down of the Buick 350cu V8( not good rev type mtr but very torquey ) which showed up in 74 models to save fuel from the OPEC oil embargo of that period. The best 6cyl mtr Holden ever had was the RB30 in the VL's |
#21 | ||
Umm here are some power figures from the BF workshop manual some of you might find interesting.
General Specifications Description Specification Displacement 3984cc Number of cylinders In line 6 Compression Ratio DOHC VCT 10.3:1 Turbo 8.7:1 Power at specified rpm(DIN) DOHC VCT 187 kW @ 5000 LPG 156 kW @ 4750 Turbo 245 kW @5250 Torque at specified rpm (DIN) DOHC VCT 390 Nm @ 3250 LPG 372 Nm @ 3000 Turbo 480 Nm @ 2000-4500 Bore/Stroke 92.25mm / 99.31mm Firing Order 1-5-3-6-2-4 Oil Pressure - 2000 rpm @ 80 °C (normal operating temperature) Oil Pressure - 700 rpm (idle) @ 80 °C (normal operating temperature) 300 kPa minimum 120 kPa minimum Spark Plug - I6 DOHC VCT AGSP 22YE13 LPG AGSP 22YE07 Turbo AGSP 22YE09 Compression Pressure at Maximum cranking speed DOHC VCT 1010 Kpa LPG 1110 Kpa Turbo TBA Idle Speed Manual Trans (A/C off) DOHC VCT 700 ± 50 rpm LPG 700 ± 50 rpm Turbo 700 ± 50 rpm Auto trans in Neutral DOHC VCT 700 ± 50 rpm LPG 700 ± 50 rpm Turbo 660 ± 50 rpm Auto Trans in Drive DOHC VCT 530 ± 50 rpm BF00006 en 01/2006 2006.0 BF Falcon |
#22 | |||
100% agree with that i owned vy commy v6 ( just sold it ) and it had no torque what so ever and slow as all fook. and also blow the gearbox at 45,000kms and holden are fags and wouldnt replace it i had to get it reconditoned out of warrenty.. Lost all respect for holden and would never buy 1 ever again.. i drive perents deawoo atm till i finish getting finance for my house i will be going a xr6t ![]() |
#23 | |||
Force Fed Fords
#24 | |||
The RB30 is a nissan engine, not a holden one, and that old holden v6 is decades old, finding origins in its bore spacing as far back as some engines produced in the 60's (possibly earlier)... The current Holden v6 sounds no better than that old engine, seems to be just as harsh up top and performs little better as well. Pretty sad if you ask me... Especially considering that the car it has to pull around is roughly 100kg's lighter (in the base model, even lighter still in other models), compared to the Falcon. My 2c. |
#25 | ||
[QUOTE=Lawsy]Please don't type like this is an sms message, you have plenty of space to type things out in full so people can more easily comprehend what the meaning is.
The RB30 is a nissan engine, not a holden one The only word i can see in buicks post thats not in full is motor (mtr) and if you carn't work that out you should be ashamed of yourself also he didn't say the RB30 was a holden engine he said it was the best engine holden had ![]()
XD with EL xr8 front 393 12.1 114mph on lpg: Sold
FG F6 Manual 366RWKW tuned by BLUE POWER ![]() ![]() ![]() ![]() ![]() |
#26 | |||
Yes the Nissan motor was a good one...Strange it was really only for Aust...
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 Last edited by ebxr8240; 24-02-2006 at 11:51 PM. |
#27 | |||
Peter Car
#28 | ||
buickman
[QUOTE=Lawsy]
The RB30 is a nissan engine, not a holden one, and that old holden v6 is decades old, finding origins in its bore spacing as far back as some engines produced in the 60's (possibly earlier)... QUOTE] It might be a Nissian sourced mtr but its still the best 6cyl mtr they have ever fitted to their cars. The odd & even fire Buick V6 mtrs appeared in 1974 that went on to power the VN-VY. But they are of the same family as the Rover V8's used first in the 1962 Skylarks . |
#29 | ||
Like I say the RB30 was the best 6 Holden never built.
#30 | |||
