Old 09-03-2006, 11:58 AM   #1
neilo
Question A/C Filter??
Hi all,
First time poster, but been reading the forums for a bit fixing a few minor, expected problems with my 77,300km AU Classic.
Anyway, it's in for an A/C regas today, and mention was made of a filter that the Falcons supposedly need. It's optional, apparently, for the car but for a "good service", it should be fitted.
Now, this is the first time the a/c's been touched since I bought the car new, and there's no other problem with it other than not as cold as it use to be.
Is this actually reasonable or am I getting dudded?
Thanks,
Neil
neilo is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2006, 12:03 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
pollen filter...?
As for not as cold , was the car moving or stationary etc as this makes a difference also.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 09-03-2006, 12:04 PM   #3
BlackLS
Au's didn't have pollen filters?
Old 09-03-2006, 12:05 PM   #4
phildee
phildee's Avatar
Possibly reffering to the dryer/filter in the air con loop?
They should be replaced if the loop has been opened, didnt think they would need to if its just a standard regas.
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2006, 12:07 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Cheap insurance wouldnt it be to get a new receiver/drier
13.21 @107.7mph
Old 09-03-2006, 12:13 PM   #6
neilo
@svo347, It just isn't as cold as it use to be, either moving or standing. Heck; my wife's Kia Rio has colder a/c.
Fair enough, though. I'll get him to replace the filter.
Old 09-03-2006, 03:52 PM   #7
Axle-F
AU - YEA YOU!
Axle-F's Avatar
air filters do get old, so will need replacing.
i just got my AU regassed (at 80,000km) and cost me friggen $1,500 cause all the seals were wrecked. i'm still hurting from that bill.
AU II XR6 VCT - JMM DEV3+
Axle-F is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2006, 04:30 PM   #8
neilo
Please tell me there were other symptoms other than it needed a regas...
Old 09-03-2006, 05:16 PM   #9
Axle-F
AU - YEA YOU!
Axle-F's Avatar
Yep. Because the seals were destroyed the AC specialist had to go through it for a number of hours with an irridescant torch to determine exactly which seals were broken, then they all needed to be replaced. This had to happen twice since there were many subtle leaks through the system.
Basically the previous owner had never run the air conditioning enough so all the seals were fecked and difficult to repair. :
Old 09-03-2006, 05:50 PM   #10
philstoj
philstoj's Avatar
If your AC isnt working well, running intermittently or not blowing cold air then the most probable cause is a blockage of the line at the filter. now theres a particular name for it but i cant think of it now.
Had this done as mine was playing up, and its a common problem for cars that run this sort of AC system.
Mine was completely blocked by metal particles (which came from the compressor) so was replaced and had my AC gas put back in (as they need to recover it).
Even after checking the system pressure (was fine) the AC wasnt working, tracked it down to being a blockage.
$180 later and is all good now.
Old 09-03-2006, 07:47 PM   #11
svo347
AFF's 1st DM.......
svo347's Avatar
TX Valve?
13.21 @107.7mph
Old 09-03-2006, 09:10 PM   #12
miitch
orgasmic.
miitch's Avatar
Standard practise when I work on any Air conditioning or refrigeration equipment is to change over [when charging system with gas or system is open to air] what is known as a 'drier', sometimes they become blocked and this will affect the operation of the TX Valve by limiting the refrigerant flow. It would be a good idea to have this replaced if that's what you are talking about.
Don't quote me i'm only just into my 2nd year as a refrig apprentice and I don't do any work on cars.
1999 AUI Fairmont
Dynamic White, King Superlows, Tickford Intake, Pioneer DEH-P6850MP HU, Clarion SRC5715 5x7s (rears), Clarion APA2001 Amplifier running a Pioneer 12" Sub.
121.0rwkw
miitch is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2006, 10:46 PM   #13
HLC
Audi S3
my aircon blows white gas sometimes :|
but it's cold as :|
Old 09-03-2006, 10:55 PM   #14
miitch
orgasmic.
miitch's Avatar
Does this 'gas' have any sort of smell to it? It could just be humidity.
1999 AUI Fairmont
121.0rwkw
Old 09-03-2006, 11:22 PM   #15
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
I can tell you for a fact from a mate in the refridgeration business - cars and companys - i was told - and it makes sence to me too - that tuning the car off with the aircon still goin can dry/freeze the seals too , you should allways switch off your aircon a few mins prior to stoping your car to alow the heat off the engine to bring all the seals down to a normal temp again in the aircon unit. I have followed this rule for years too and never had a problem or need to regas, so i think he was onto somthing right ! .
:eclipsee_
Old 09-03-2006, 11:28 PM   #16
miitch
orgasmic.
miitch's Avatar
Turning the car off would dswitch off the fans that the aircon system would need to run efficiently, without a fan on the evaporator for example, the refrigerant would simply ice up the evap coil and could potentially damage seals.
1999 AUI Fairmont
121.0rwkw
Old 09-03-2006, 11:48 PM   #17
XR6-VCT-2000
Fantastic Plastic
i dont think you read/understood what i wrote correct ..im not saying run the aircon with the car off ! ..
:eclipsee_
Old 10-03-2006, 12:59 AM   #18
miitch
orgasmic.
miitch's Avatar
Either way it shouldn't make a difference then, sorry - got a bit carried away.
Small amounts of oil will travel through a system with the refrigerant, the oil lubricates o-rings and seals etc, so therefore, all you should have to do to keep them from wearing out is to run your aircon atleast once or twice a week, this is recommended in most user guides/manuals anyway.
1999 AUI Fairmont
121.0rwkw
