13-03-2006, 10:31 PM | #1 | ||
FRIKA
Just looking at getting some 19" rims 19x8.5 tyres 245/35. My car has been lowered King Ultra low. Anyone got a similar set up. Im trying to find out if the new setup will damage my guards. Im not sure if maybe i get 235/35 tyres instead.
New 2008 LV Focus XR5 in Performance Blue
13-03-2006, 10:45 PM | #2 | ||
Your guards will need to be rolled..
13-03-2006, 11:03 PM | #3 | ||
they call me Tibbo
I think 012 had the same set-up and the rear tyres fouled on something when going over bumps??
14-03-2006, 11:37 AM | #4 | ||
Not of the Sooty variety!
You should be ok on the rear with that width (depending on offset), but if you go wider the tyre can rub on the plastic cover on the inside of the guard. Pushing it out with a heat gun and a couple of taps with a hammer should sort that out. As mentioned best get the guards rolled.
"To be afraid is to be alive - to act against that fear is to be a person of courage." Current
The Toy: 2002 AUIII TS50 The Daily and Tow Vehicle: 2016 VW Amarok |
14-03-2006, 12:05 PM | #5 | ||
Whats the difference between superlow and ultralow?
14-03-2006, 12:22 PM | #6 | |||
they call me Tibbo
14-03-2006, 03:15 PM | #7 | |||
XB in parts...
14-03-2006, 03:25 PM | #8 | ||
Last I got quoted was $45-$50 a guard.. but that was when I was planning for 19's..
not really an issues with 18's. |
14-03-2006, 03:28 PM | #9 | ||
what do they do exactly when they "roll" the guards.. wouldnt it damage your paint?
14-03-2006, 03:34 PM | #10 | |||
they call me Tibbo
14-03-2006, 04:38 PM | #11 | ||
and easy way to do it is to take a Jigsaw to the 90 degree lip and put little slices into it about every inch or so.. and then use a mallet to bend them back.. works a treat..
its time consuming though.. |
14-03-2006, 06:05 PM | #12 | ||
OLD SKOOL BABY
Getting my guards rolled tomorrow on my AU with a roller type machine that bolts on to the wheel hub, I also asked the guy if he does hot or cold rolls and tells me he heats it up first to soften the paint then rolls. Heard that is the better way to prevent paint cracking rather than cold.
Will let you guys know tomorrow and hopefully some pics. Also the gut tells me that if the paint does crack it's on the inside where you can't notice it. Mick
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP 83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.1976 XB GS COUPE (waiting to start the rebuild)
14-03-2006, 07:02 PM | #13 | ||
FRIKA
Excellent feedback thanks. Will cost me $60 per guard. For those that have 19" rims what size tyres do you have. should i get 235 or 245?
14-03-2006, 10:33 PM | #14 | ||
T3/Sprint8
as Grunter mentioned the right offset is important.
I have 9.5" at the rear no worries at all. Front 8.5" no rolled gaurds, mind you I do rub if I drove agressively into a driveway or similar.
15-03-2006, 01:28 AM | #15 | ||
FRIKA
Once i get them ill see how i go. can always get them rolled after if required.
