Old 20-05-2006, 05:12 PM   #1
ziggee
Default Short Shifter BA-AU
Sorry, NOOB question #2.
Does anybody know if a "short" shifter from a BA, will fit into a AU?
Dude, has a BA 5 speed, I have AU 5 Speed.
Old 20-05-2006, 09:07 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
dunno , but there's nothing stopping you chopping your origininal gear shift bar to the suited length and re-threading the end of it, people been doin this for years . ;) .
:eclipsee_
Old 20-05-2006, 11:31 PM   #3
loxxr6
XB in parts...
loxxr6's Avatar
BPT has the shortened gearsticks if that's what you're after for real cheap.
Old 21-05-2006, 01:14 AM   #4
ziggee
Cheers. I am hoping someone might know if BA Shifter will Fit onto a AU, as I have opp to buy one cheap.
I did have a look at BTP http://norcom.net.au/~bpt/gear%20lev...%20turrets.htm
but the one I am looking at is cheaper than this.
Failing that, I may just in fact chop it myself as suggested...
Old 21-05-2006, 02:49 AM   #5
XR6-VCT-2000
Fantastic Plastic
Yeah mate - cut the original to size ;) - is easy as pie , don't even need to uninstall it , just use a hacksaw , not a grinder, to be safe from sparks/fire , get yaself a tool for re-threading (tap and die set , just need the die) the end of the chopped shaft ( few $$ , way cheaper than a new stick ) .. ;) .
:eclipsee_
Old 21-05-2006, 10:54 AM   #6
LG
LG's Avatar
Are you talking about a Shortened Gear Lever or a Short Shifter.
If your talking about a Short Shifter, like you said.
If the BA is a T5, and it is not from a GT with a T56. Then it should go. Best bet would be to ask one of our sponsor's.
Old 21-05-2006, 01:53 PM   #7
ziggee
sorry for the confusion. I am talking about the bar/pole/gearlevel (that the knob fits on). I have an opp to buy one cheap <$40 but its out of a BA, and am not sure if this would infact fit into/onto the bit thats ontop of the gearbox. 5 speed manual AUI
sorry don't know all the terminology
Old 22-05-2006, 05:32 PM   #8
loxxr6
XB in parts...
loxxr6's Avatar
In that case if it's just the shorter "stick" that the gear knob sits onto, then XR6-VCT-2000's & LG's advice will be right.
Old 22-05-2006, 05:38 PM   #9
347_XR8
Slide Baby Slide
347_XR8's Avatar
Get a Rip Shifter. Check out Aussie Car Enhancements section for more details. It's better then any short shifter and will fit the 5spd on any Falcon.
:the_finge You want more inches...........STROKE IT!!! :the_finge
Mr Super Skid-Man
347_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2006, 08:28 PM   #10
ziggee
Default Diy
From this (Shifter in Reverse Gear)
to this... atleast 50mm shorter. (in reverse gear cam angle is a lil different sorry about the mess in the ute doh!)
Might to a DIY Howto (so noobs like me can do it).. easy as...
Old 27-05-2006, 03:33 AM   #11
XR6-VCT-2000
Fantastic Plastic
you chopped the original yeah ? , i gather you did as i can see a tap and die set on the fron passengers seat in the pics ..lol ;) - way to go . .. nice job , now you have yourself a tap and die set for the price of a shorter bar , sure to come in handy later too ;) .. Actually easier than changing the bar to a shorter one imo .
:eclipsee_
Old 27-05-2006, 03:54 AM   #12
ziggee
hehehe, nah i had the tap and die set ages ago.... but becuase everyone on here said go for it, and how easy it is, i thought I'd give it a go...
cheers for looking at it... I was wrapped, i thought it would have been harder, i did make a mistake which required and angle grinder, as 50mm was to much, I'd love to go shorter now... just as big as your hand plus 20mm out...
not sure if it like does any damage to anything though, or makes it weaker etc etc, or puts more stress on it, will find out if/when it breaks...
now for the group buy "short shift" kit, and then I'll be happy..
Old 27-05-2006, 01:26 PM   #13
XR6-VCT-2000
Fantastic Plastic
I've never known a chopped gearstick to cause any damage ! , it's no different than a shorter stick you buy from a shop, it'll be fine ;) . Good to see it worked out well for you .
:eclipsee_
Old 27-05-2006, 02:40 PM   #14
lotus
I bought the gear stick fitted to the T series. Difference being that the origional stick is straight where the T stick is shorter and bent towards the driver. Was advised that the au's already were fitted with a short shifter,just to change the gear stick. Cost approx $100. Easy to fit ,just undo knob.remove boot and undo 2 bolts. Done in no time! Now 1st,3rd and 5th are positioned where netural was.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2006, 06:00 PM   #15
XR6-VCT-2000
Fantastic Plastic
If you want the bend in the bar that can easilly be achieved too by heating it with an oxy/blowtortch heating it up and bend it , allthough you would have to remove the bar to do this , depends how you like them anyway - personally imo i like them short but straight anyway .
:eclipsee_
