PM me if you want
Ok here goes,
We just bought a house and some taps are leaking, so i went to fix them, but I cant dissasemble the tap to replace the washers, etc. Now I believe and it has always been this way in other taps i have repaired: TURN THE WATER OFF ![]() 1. remove the little hot/cold button on top (done this) 2. remove the handle to turn tap on/off (done this) 3. remove flange (the big chrome bit) should be screw off ... IT DONT COME OFF :( :jab: 4. undo the rest of the tap bits, replace washers seals etc and put it back together. Step 4 is not happening, have I got it wrong and forgotten some basics. I have tried a big pair of adjustable pliers, i can grip it, but with all the force i can apply it just slips and does not budge. please help ![]()
maybe some WD40 may help i do this a few times a year at home and all i got to do is turn water off, dismantle the tap replace seals, washers rar rar rar and put it all together and done
hope this helps FalconSR
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
Is it a reverse thread?
LWBforME
Try a bit of CLR applied around the base of the flange/rim where the contact is made. Use a concentrate solution and allow some minutes to penetrate. (May need to brush in vigorously for a while) Also using a small block of wood and hammer tap around the base of flange in intervals (i.e, four or more spots all the way around the fitting. Try to unscew again. Often calcification causes surfaces to bond together pretty firmly! If this doesn't work and if the tap is not enamel or plastic, try some moderate heat (somewhere between a hot hairdryer and a blow-torch, using discretion and care about leaving scorch marks)
Golden rules for loosening/undoing things: 1. Dissolve 2. Shock 3. Heat 4. Grip 5. Strength! |
#5 | |||
PM me if you want
#6 | |||
and if the previous person to work on the taps didn't and you manage to get them loose, put plumbers tape on the thread to help prevent bonding together like it seems you're experiencing.
PM me if you want
thanks for that tip, we plan to get new taps as we dont like the current ones, but I have to stop the leaks for now, one it costs money and 2 it will case damp problems if left as is.
sorry to hijack the thread, another plumbing question..how easy is it replace the 1/4 turn ceramic tap's(the washer kit costs about $25 to replace) with the conventional type tap that people have mentioned here??
cheers andrew |
#9 | |||
#10 | |||
PM me if you want
#11 | |||
Cranky old bastard
(Stillsons are an adjustable wrench with big teeth to dig in) |
#12 | |||
Cranky old bastard
#13 | |||
PM me if you want
#14 | |||
Cuban... nothing like it
Need pictures to answer you correctly
#15 | |||
LWBforME
Anyway, how's it going ? You got it undone yet? Chances are the seats will be pitted and corroded too so you'll have to re-grind them too. Bloody little jobs always turn into Ben Hur productions!!! I'm thinking bite the bullet and get the new taps now, cause your best to get a plumber to install them. Can be pretty tricky. |
#16 | |||
Weezland
#17 | |||
Weezland
#18 | |||
Motel XC
#19 | ||
Weezland
basin set will cost you more than $25, just buy the spindles if its on the basin
#20 | ||
PM me if you want
Need to get the stilsons out, well buy/borrow some to fix this tap, got all the bits to go in, just can't get the tap apart to put the bits in.
#21 | |||
Cranky old bastard
#22 | |||
thanks andrew |
#23 | |||
cheers andrew |
#24 | |||
Weezland
