Old 17-07-2006, 01:34 PM   #1
DENKO
Bseries hardcore
Default Annoying Buzzing
I have an annoying buzzing sound from my system in my car, it goes with the revs of my car and now its really annoying and you can always hear it, ive ran the power cable and speak cable seperate, ive seperated the RCA's and some of it stopped but its still loud! any suggestions on how to fix it?
HISTORY:
AU series 2 S pack manual
BA XR6 mock up [FLINBY]
BF MKII XR8, 13.8 @ 107mph
BA MKII F6 TYPHOON
BA MKII XR6 TURBO
BF MKII F6 TYPHOON R-spec, 13.2 @ 109 mph [LTHLF-6]
PX Ranger WILDTRAK
DENKO is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2006, 02:57 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
get yaself a car noise filter from jaycar , they are pretty cheap
the 5amp unit http://www.jaycar.com.au/productView...Max=&SUBCATID=
the 20amp unit http://www.jaycar.com.au/productView...Max=&SUBCATID=
or the 40amp unit http://www.jaycar.com.au/productView...Max=&SUBCATID=
cheers .
:eclipsee_
Old 17-07-2006, 04:28 PM   #3
DENKO
Bseries hardcore
my brother has one in his car but the noise filter then cut out his bass!
HISTORY:
BA MKII F6 TYPHOON
BA MKII XR6 TURBO
PX Ranger WILDTRAK
Old 17-07-2006, 04:55 PM   #4
jones_aus
jones_aus's Avatar
it could the earth for your amp, make sure its got a good earth point
jones_aus is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2006, 07:02 PM   #5
Stav
Smile
Stav's Avatar
you have a bad earth somewhere mate.
Old 17-07-2006, 07:39 PM   #6
XR6 Freek
my earth is under the under the back seats on the shell
XR6 Freek is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2006, 07:40 PM   #7
XR6 Freek
its S-man just on my cousins account! sorry for the confusion
Old 18-07-2006, 08:17 AM   #8
XR6-VCT-2000
Fantastic Plastic
If the noise is that bad, try running the earth from the headunit and amp all to 1 point.
(Use nice thick ground leads).
If you are running an amp too , are you using decent quality shielded coax cable ?
The gold tip plated plugs help remove noise a tadd too , if your doing all the above / and have a good earth / then your probably gonna have to go for a noise filter as i mentioned earlier.
By the sounds of the 1 your brother got , it is cutting into the db. range to earlly (thus cutting the base out ) , it is over filtering .
I haven't checked out the jaycar ones personally , but i have seen good noise filters in the past that have had a variable knob/dial on it so you can adjust the filter until it just cuts the noise out / and doesn't start cutting into the musics db. range. / it was almost sorta worked like a squelch dial you find on a cb radio.
gl , cheers .
:eclipsee_
Old 18-07-2006, 07:35 PM   #9
normell
A couple of years ago I had a top of the line Pioneer system fitted by JB Hi Fi, to my dedicated gas AUIII, couldn't get rid of the noise.
Turned out to be the different iginition system on the straight gas motors
Normell
Every day above ground is a good day.
Still Drinking & Driving, But Not At The Same Time
normell is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2006, 02:47 PM   #10
DENKO
Bseries hardcore
thanx for that guys, i spoke to an auto elec to re wire it for me so hopefully he gets rid of the noise, gl, i do have thje gold plugs in, thanks for your help anyways!
HISTORY:
BA MKII F6 TYPHOON
BA MKII XR6 TURBO
PX Ranger WILDTRAK
