Who has a driveway cleaning method that works ?
I need something other than degreaser. Thanks Stewiefishing |
coke?
FTF Club Moderator
Mythbusters used to coke to clean dried blood of concrete. If it can remove blood it may be good.
Chlorine will pretty much remove anything. Just dilute it down and use safely.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
trying to get a leg over
![]() Join Date: Dec 2004
A good quality truck de-greaser like "Ripp Off", let it soak in, then blast it with a high pressure washer.
Cameron ------------------------------------------------------ |
V8 Powaah
Good quality degreaser + gurney is what I use and its the best i can think of.
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
#6 | |||
Purveyor of filth
#7 | |||
Get rid of any Holdens sitting in it
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo |
#9 | |||
Jim
http://snat.sn.funpic.org/ |
PM me if you want
Kerosone, scrub, hose, detergant mix, scrub, hose
all clean
sand-blast.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
#12 | ||||
Caustic-Soda, Give it a good brush with a stiff broom
#14 | |||
If it is bitumen do not use degreaser or kero or anything petroleum based as it will break it down! Cheers Autocade |
#15 | ||||
Force Fed Fords
Bluemist is 100% right
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
#16 | ||
TUFF FORDS
hydro-cloric acid is good dilute it a little wet the concrete get a stiff broom and broom it on,it will start to react and bubble and fizz,scrub the whole driveway like this.. hose of within about half hr of when you first started but, and where a breathing mask.. it cleans the cement like the day it was laid and leave's a nice etch on the concrete as well
#17 | ||
LWBforME
Down here in SA you're not allowed to hose down a driveway I think (Water restrictions) so I opt for dry methods. Soak up oil spills with sand sweep up & so on.
#18 | ||
having time of her life!
To remove oil stains, first blot any excess with something absorbent such as old newspaper or cat litter (work it in with a stiff broom), then blot again with a rag soaked in a grease solvent. Suitable solvents include metho & turpentine. You can also try a strong household bleach cleaner. Make up a high-strength solution according to the manufacturer's instructions, apply liberally on the stain, leave for 10 minutes and then wash away.
We get a box of the RSPCA kitty litter and always have it in the garage, with the old ute we used to have malfunctions regularly and have to soak up a nice coolant & oil mix. I was also known to attack the oil stains in our garage with hot water and good quality dish washing liquid. I have also been known to make a past of automatic dish washing powder, put that on it for a while and then rinse it off. If you want to spruce up your concrete, sprinkle cement powder over wet concrete and leave for about 10 minutes before sweeping up the excess.
1963 Chev Impala | Black | 2 door ![]() Mazda 2 | Turbo (custom) | Spicy Orange <- punkin |
#19 | |||
Force Fed Fords
Strategically park some Holden commodores and you will soon cover the driveway with oil stains, then it will look uniform and you won't need to clean it.
#20 | |||
Force Fed Fords
Actually, if you spill paint and crap all over it, you can call it impressionists art. The art gallery will buy the driveway from you. When you're negotiating with them you can put on a really droll sort of cocknie accent and say; "it's about the challenges of man in modern society, and how our introspective issues are brought to the surface through egalitarianism and societal decay"
That should be worth a couple hundred grand to an art museum. Then with the money raised buy a new driveway.
#21 | ||
likes falcon's
don't drive a car that has oil leaks and don't do oil changes!!! lol
www.carhubsales.com.au |
#22 | |||
likes falcon's
wouldn't it be cheaper to get degreaser lol cost of sugar isn't very low
#23 | ||
Matakana NZ
![]() Join Date: Aug 2005
OK Guys, so how do you get power steering fluid off that you visitors leave on the tar seal?
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one. My Work Wagon AU Futura Wagon in Gold. On the Farm : Ford 6600 Tractor |
#24 | ||
PM me if you want
Here is a very intersting way to do it, and not much effort
http://www.csiro.au/helix/experiments/OilConcrete.shtml For the tar seal driveway try plain old kitty litter.
