3 Pedals R Better Than 2
I've finally got around to removing all the dodgy teflon tape from a few fuel line AN fittings.
Just wondering what's the best thread sealer to use (I'm just using this on the fixed tapered fittings). None of the 4 auto shops I went into had any that specified fuel proof or resistant. Couldn't find anything listed in the Loctite catalogue either. One guy recommended this joining paste goup called "Stag"......but surely there's some specific fuel thread stuff on the market? Cheers |
TUFF FORDS
i've never used and sealer on tapered fittings for fuel mate and they've never leaked.. never really known anyone to use anything on tapered fittings really as there's no need.. unless I'm lucky..lol..
LIFELONG DJR SUPPORTER
Tapered thread fittings, like on Brakes and Fuel lines do not require sealant on the thread, as if tightened well enough, can not leak.
Cheers, Mike
Well that was easy then. Cheers
The Fun Mobile
I allways use the loctite pipe sealant 567 (with teflon in it) as it stops any galling of the threads and seals well. It may not need it, but i have allways used it with 100% success(and i sell it so suply is not a problem
408 cube Cleveland TFC @ AFD 2V, 750 DP 10.7 @ 125 mph 2V powahhhhh |
LocTight 569 if you want to use a sealer on your fuel system fittings, that’s all we use it’s a hydraulic sealant but will not be broken down buy fuel.
![]() Join Date: Dec 2004
Same as XD clevo ,loctite 569 sparingly or Wurths do a nice pipe sealant too.
That loctite 569 rocks! I see what you mean by sparingly. Cheers
Ummm? I said it rocked because it looked like someone put some on a few of the new bungs on my engine (white pastey stuff that sets really firm), but.......
I've used some new stuff today and it's now been 12 hours and it's still runny like it came out of the tube!? Does this stuff have a "use by" date? I noticed the new packet was sun faded like it had been in the shop for about 10 years. Could this cause it to go off and not set? It's supposed to be fast curing. |
Most of these kind of products (loctite) have a use by date. After a while (couple of years) you'll find they seperate into their base ingredients. AN fittings seal on a tapered face much the same as JIC or a barrel union. The threads don't actually do any sealing except for drawing pressure upon the two mating surfaces, as such they don't require a sealant. Unless your pulling the things apart every weekend I wouldn't bother with a lubricant for the threads, just remember that some of these tapered seals are matched machined meaning you can't just chop and change between male and female components. Generally AN (Army/Navy) are safe to use non-matched sets.
Bolt Nerd
![]() Join Date: Jan 2005
If it's a FLARED fitting.. No locktite, stag or whatever... the sealing faces are metal to metal and compressed by nut pressure. You guys recomending these "goos".. would you honestly use it on brake lines?.. These being double flares?.
If a tapered BSP or NPT thread then Yes.. Loctite fuel resistant thread sealant. If a parallel BSP or NPT thread you use a "dowty", copper or fibre washer
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner ![]() |
#12 | |||
Weezland
#13 | |||
#14 | |||
#15 | |||
Weezland
#16 | |||
#17 | ||
The Fun Mobile
double post
408 cube Cleveland TFC @ AFD 2V, 750 DP 10.7 @ 125 mph 2V powahhhhh Last edited by xdclevo; 07-01-2007 at 03:38 PM. |
#18 | |||
The Fun Mobile
Adrian, did you use the 569 red, or the white 567 pipe sealant? (the red bottle ones are anerobic, that is why you only get 1/2 a bottle from the shop, so it doesnt cure in the container.)
#19 | ||
Yeah, I used the 50ml white tube (red writing) 567 with Teflon. (BIG tube for 50ml!!)
I squirted some on some cardboard last night and smeared it around thinly, but it's still quite wet and pastey. It just wiped all the excess sealant which squeezed out of the threads hoping to find rock paydirt underneath, but it's all still wet and pastey. I pulled the fittings out and it's all the same & it was over 24hr ago since fitting....not sure what "RAPID CURE" on the tube means ![]() I've only used it on oil and water bung/temp fittings in the block. Here's the tech sheet: http://www.rpipartsdb.com/ds/56707tds.pdf |
#20 | ||
The Fun Mobile
(u confused me with saying 569)
The 567 is supposed to stay like that. Stop torchuring yourself, refit with "567" white paste and forget it man. I have been selling and using it for 16 years, i know what i'm on about :evil3: Have a look on you link about full cure time. More than 72 hours.
#21 | |||
![]() Yeah, just saw the long cure time with the brass fittings. Someone close this thread so I can stop making a fool of myself! :lookedat: |
#22 | ||
Weezland
It wont cure in the bottle either,which comes full and sealed,it cures almost immediately when compressed,thats how its meant to work..
#23 | ||
Quote
“If it's a FLARED fitting.. No locktite, stag or whatever... the sealing faces are metal to metal and compressed by nut pressure” True we use allot of JIC fittings at work on Fuel, Hydraulic, Lube oil systems and we normally use 569 only on the Flared faces as piece of mind. Cause even know you tighten the Christ out of them sometimes they occasionally leak, and when it can take you 4-8hrs to get to where the leak is the Boss isn’t to impressed when all that was needed was a light application of 569 to the flared face at she sealed perfectly. |
#24 | |||
The Fun Mobile
#25 | |||
