Old 04-02-2007, 09:04 PM   #1
Auuteage
Default Strange sound when engaging clutch
Every time I engage the clutch I get a strange loud squeaking sound. Sounds like its coming from behind the cabin in the rear of the ute somewhere.
Along with this sound is also a small , almost a grinding type of noise. Dont know how long that ones been around, but just noticed when listening more carefully to the squeaking. Any ideas ?
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2007, 09:32 PM   #2
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Sounds like the thrust/release bearing for the clutch.
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2007, 10:21 PM   #3
Auuteage
a expensive part ?
Old 04-02-2007, 11:12 PM   #4
EvilChief
Boost Addict
about $15 bucks
but takes about 4h to change
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 04-02-2007, 11:14 PM   #5
Auuteage
damn, that would be right. Hard to change for a novice I guess? Or worth a attempt with the right info?
Old 04-02-2007, 11:31 PM   #6
EvilChief
Boost Addict
remove tailshaft
remove gearbox
throwout bearing sits on input shaft actuated by clutch fork
while u are there i would suggest to inspect friction plate for wear, pressure plate for heat spots and flywheel for lip and heatspots
plus check gearbox oil, rear main seal for oil leak and shifter bushes for wear.
thats what i would do, as for being hard .. no not really, just pain in the butt
N12 Pulsar - sold
Old 04-02-2007, 11:52 PM   #7
Auuteage
whoa whoa! I think ill talk to my mechanic. "0)
Old 04-02-2007, 11:57 PM   #8
Auuteage
Will it perfrom ok till I get round to fixing it. Or is likely to crap out on me ?
Old 05-02-2007, 12:11 AM   #9
EvilChief
Boost Addict
throwout bearing can seize which then can wear into the pressure plate fingers, but i havent seen one fail from one day to another
N12 Pulsar - sold
Old 06-02-2007, 07:18 PM   #10
Auuteage
ok guys,
This problem really sounds like a water pump with a thrown bearing, but its definately not the pump. It must be a thrust bearing or something caquse the sound changes with the clutch engaged, and its worse in lower gears than higher ones.
I have to drive it all day for three nmore days till I can get it fixed on the weekend. Am I likely to get away with it ? thanks.
Old 06-02-2007, 07:38 PM   #11
S3SR
S3SR's Avatar
cars suck dont they, ive got an AC clutch and other things going on with my clutch as well
good luck man 4hrs under the car....id be locked up for swearing excessively
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2007, 08:45 PM   #12
Auuteage
Yeah its a *****, especially when I work as a courier, no car, no pay.
A/C clutch hey? Anyway of telling in a pinch if that MAY be my problem? Im guessing if I dont have the fan running, and that metallic grinding sound is there, then it isnt the problem?
Old 06-02-2007, 08:46 PM   #13
Auuteage
Id happily spend 4 hours under the car if I knew what the hell what I was doing! :nutsycuck
Old 07-02-2007, 06:36 PM   #14
Auuteage
Now everytime I engage the clutch, the car makes a very loud high pitched squealing sound.
Im thinking its the the clutch cable seeing last service they told me it was stretched. Can a dud clutch cable cause this problem? The car is going in on the weekend, im trying to get a idea before then. Thanks again
Old 07-02-2007, 11:25 PM   #15
EvilChief
Boost Addict
does it get harder to engage gears? stretched cable would cause for the clutch not to completely engage ...
as for squeeling ... not really
N12 Pulsar - sold
Old 07-02-2007, 11:46 PM   #16
Auuteage
yep gears get harder to change. Squeeling, thrust bearing, im hoping. As it could be worse...
The squeel is incredubly loud
