Old 04-02-2007, 09:42 PM   #1
Futura01
horsepower
Default upgrade map sensor??
Is it possible with an edit on a au falcon ECU to upgrade to a 2 or 3 bar map sensor, can a edit change the strategies to work such thing??
I know it is possible with some EEC strategies to change the MAP sensor for one that can measure more boost (i.e. a 2 or 3 bar MAP sensor). This has been done a few times on BA and BF's for tuning turbo and supercharger conversions.
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2007, 11:27 PM   #2
EvilChief
Boost Addict
i could understand on an BA and BF as there are turbo factory models available
i have NFI how and edit works so NFI
All map sensor work within the the same voltage range 0.5 to 4.9 volts
1 BAR 0.5V = 1 BAR neg, 4.9V is 0 BAR
2 BAR 0.5V = 1 BAR neg, 2.75V = 0 BAR, 4.9V = 1 BAR pos
3 BAR 0.5V = 1 BAR neg, 2V = 0 BAR, 3.5V = 1 BAR pos, 4.9V = 3 BAR pos
seeing from that the resolution of the fuel and ignition map decreases with the increase of size of a MAP sensor
so for example u have 64 tuning points for 1 BAR on a 1 BAR map sensors, u will have only 32 tuning points for each BAR on a 2 BAR map sensor and 21/22 tuning points for each BAR on a 3 BAR map sensor.
so if a edit can reprogram the actual fuel map to allow the split of tuning points between positive and negative pressure, then yes in theory it can be done.
i hope that sorta points into the right direction of your question
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 05-02-2007, 02:25 PM   #3
Futura01
horsepower
EvilChief you have lost me with all that technical wizzary !! lol
I do sort of understand what u mean, so does anybody know if the edit can reprogram the fuel map points or has anybody tried such a thing ?????
Old 07-02-2007, 02:50 PM   #4
xr8ute
Back on the road
xr8ute's Avatar
Dude, speak to Headsex...or Martin Donnin.
They have both done this on non-turbo BA/BF Falcons for supercharger and turbo conversions. If it can be (or has already been) done on an AU, then I am sure they would know.
Old 07-02-2007, 03:34 PM   #5
EA2BA
PM me if you want
EA2BA's Avatar
I thought up to EL ran a MAP sensor, and since the AU they run MAF sensors in the i6 anyways, or am I wrong.
Old 07-02-2007, 03:52 PM   #6
xr8ute
Back on the road
xr8ute's Avatar
Nope.
The only EFI I6 Falcons to use airflow meters, where the XE and XF Falcons (using a vane-type airflow meter).
All E-Series and AU V8's where MAF based.
All BA/BF's regardless of I6 or V8 are MAP based.
Old 07-02-2007, 04:04 PM   #7
EA2BA
PM me if you want
EA2BA's Avatar
Oh ok then, cant say I have ever seen one on an AU, where do they hide them and anyone got a pic please.
Old 07-02-2007, 11:27 PM   #8
EvilChief
Boost Addict
absolutely not ... all EFI OHC I6s are and were MAP
N12 Pulsar - sold
