Old 08-02-2007, 04:34 PM   #1
Snax
Default Engine Light on??
Hey Guys
My engine light on my dash board is on, I was wondering if anyone has experience this problem? If so what was wrong with the car? how much did it cost to fix?
Thanks
Snax is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 05:27 PM   #2
FOCUSonTHIS
FOCUSonTHIS's Avatar
Could be a million problems. Take it to your local Ford dealer so they can find out the problem. To reset the ECU cost me $45.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 08-02-2007, 05:36 PM   #3
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
1) Insert Key (do NOT turn it)
2) Press and hold the Trip-Meter Reset Button on the left indicator leaver
3) While holding the reset button, start your car and continue holding the button.
4) When "TEST" is displayed, Quickly let go of the button and press it
5) Pressing the button will now cycle through some 15 different modes.
1. Gauge Sweep
2. Fill in All LCD
3. Indicator Bulbs
4. ROM level
5. NVM level
6. DTC (Diagnostic Trouble Codes)
7. Road Speed MPH
8. Road Speed KPH
9. Engine Speed RPM
10. Fuel Volume
11. Engine Coolant Temp
12. Battery Voltage
13. ABS fail
14. Electronic Brake Distribution Failure
15. Illumination
16. Crank Sense
When you reach DTC, it will display ALL of your recorded diagnostic codes like this DTC#1 XXXX, DTC#2 XXXX.
It flicks through this very quickly, and keeps cycling through them.
Write them all down and come back with the results.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 06:40 PM   #4
zetec
Zoom Zoom
zetec's Avatar
It means the engine is feeling small and it wants you to install another 4 cylinders...
http://www.focusfanatics.com/news/im...03_rs8_006.jpg
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 08:08 PM   #5
Snax
1. Gauge Sweep
2. Fill in All LCD
3. Indicator Bulbs
4. ROM level
5. NVM level
7. Road Speed MPH
8. Road Speed KPH
9. Engine Speed RPM
10. Fuel Volume
12. Battery Voltage
13. ABS fail
15. Illumination
16. Crank Sense
Did wat you say but DTC said "none"
Old 08-02-2007, 10:28 PM   #6
QLDxr
Hey Snax....told you to buy my ST! :-)
(AKA - Mikey B)
QLDxr is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 10:54 PM   #7
eXtremist
eXtremist's Avatar
Unfortunately, you've got to take your car to Ford.
I hope its still under warranty.
Old 08-02-2007, 11:18 PM   #8
ozracer
Does that mean effectively with these ecu's you dont need a scan gauge to decipher ecl codes?
ozracer is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2007, 11:32 PM   #9
Piotr
Non-Regular Member
Well you can find out what the problem is but for most things you will need Ford to fix it and to clear the error code.
Old 09-02-2007, 12:10 AM   #10
eXtremist
eXtremist's Avatar
Error code doesn't need to be cleared to turn the engine light off.
After the ECU notices the problem has been fixed, it will turn off automatically.
I'd get Ford to diagnose the problem, and I'd fix the problem myself, and if I did everything correctly, the engine light should disappear.
Old 09-02-2007, 09:22 AM   #11
photn
AFF Post NAZI
photn's Avatar
It should Still be under Warranty From the Dealer You bought it from... i think they give 3 month or 30day warranty on all cars sold?.....take it back to ware you bought it from in Rockdale and tell them to FIX it...
Old 09-02-2007, 11:11 AM   #12
More revs
Or pull the lamp out...
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2007, 11:14 AM   #13
eXtremist
eXtremist's Avatar
If he does that, he'll fail pink slip when his rego is due and will end up having to fix it in the long run.
Old 09-02-2007, 01:48 PM   #14
BlackLS
Unless your REALLY good at microsoldering, You'd probably rather want to cut your arm off with a rusty saw then try to remove the LED in the guage cluster. LOL perhaps not that extreme
